Date/Time: Tue, 04 Nov 2025 10:44:40 +0000
Stop loss didn't trigger
View Count: 1310
[2019-11-07 22:17:34]
User554317 - Posts: 59
Hi support,
I had a scary situation where I added a limit buy order on the 10yr with attached orders (stop and profit target).
I left the trade alone and the pc went to sleep.
When I got back the trade had triggered, however the stop loss did not when it went against me. The stop and profit target had simpily disappeared and the trade was at a large floating loss. I have attached the log for the day.
I am very concerned why this happened. I thought I could rely on the platform to take me out with stop order when things aren't going well and I am not at the charts.
Thanks,
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=32938
[2019-11-08 01:48:06]
First you are posting from an account which is expired. You need to log into this board with Help >> Support Board.
We see you are using CQG and there is not support for server-side bracket orders with that service.
This is dependent upon the particular external trading service being used and is explained in detail here:
Attached Orders: General Management of Attached Orders
For server-side bracket orders you need to use this service:
Sierra Chart / Trading Technologies Futures Order Routing Service
Date Time Of Last Edit: 2019-11-08 01:51:04
[2019-11-08 02:42:03]
Thanks, I did use attached orders. You can see it in the file I attached.
Are you saying that my limit and stop loss orders were not transferred to the server and therefore they didn't get triggered when PC went to sleep?
I have a sub accoutn which is subscribed to SC.
Date Time Of Last Edit: 2019-11-08 03:42:17
[2019-11-08 17:19:47]
Yes because server-side bracket orders are not supported with CQG.
You will need to switch to this service:
If you want to proceed with that service, then in step 3 in the set up instructions on that page complete the form.
And then you also need to enable this option:
Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General)
Date Time Of Last Edit: 2019-11-08 17:20:23
[2019-11-08 19:30:41]
seandunaway - Posts: 356
Can't the stop loss and limit target be submitted server-side as an OCO with CQG?
[2019-11-08 20:16:41]
Yes but the problem is that only happens when the parent order has filled. Based on the description it is quite clear, the parent order had not yet filled at the time the computer went to sleep.
Date Time Of Last Edit: 2019-11-08 20:17:34
[2019-11-09 01:35:48]
Wow I was never aware of that. Thanks for explaining. The parent order had indeed not been filled. Pretty scary that this can happen to be honest...
[2019-11-10 03:16:54]
You can tell the orders are client side when you look at the status of them on the Chart/Trading DOM and they show "Child-Client".
[2021-07-14 12:33:04]
User284416 - Posts: 27
Hello
i have similar problem but my parent order was filled, i scaled and went to sleep when half was still open. when i woke up i saw my stop and target are still there but price just went through stop 11 ticks and it still wasn't getting triggered. Checked that Global Settings >> General Trade Settings >> Use Server Side OCO Orders and Global Settings >> General Trade Settings >> Use Server Side bracket Orders are both set to yes. It's a trading evaluator account with apteros
[2021-07-14 21:11:25]
Sierra_Chart Engineering - Posts: 21299
There should not have been a problem with this. Can you make sure that Trade >> Trade Simulation Mode On is disabled?
[2021-07-14 21:21:00]
yes, it's disabled. moreover it can't even be enabled while i'm on their connection. when i want to simtrade i have to switch to sierra data feed
[2021-07-15 19:31:50]
Trade Simulation Mode can be enabled during a chart replay. So there is the possibility it could have been enabled.
We need you to provide the first two lines in the Trade Activity Log for one or both of those orders which did not fill when expected. Instructions:
Trade Activity Log: Providing Trade Activity Log Data Lines to Support
Date Time Of Last Edit: 2021-07-15 19:33:08
[2021-07-15 22:39:48]
i'm not trying to replay chart, i'm using it real-time and can't get "sim1" account option in trade window or a tick next to Trade >> Trade Simulation Mode On
Fills  2021-07-13 10:58:32.002  SILU21  Trading Evaluator order update (Filled). Info: Trade simulation fill. Bid: 26.250 Ask: 26.260 Last: 26.255. Text: Parent order. Tag: 2TargetsWithCommonStop.twconfig  26395  967483  Market  1  Sell      Filled  26.250  1  nikanikiforukgmailcom  Open    -1  967483.1      2TargetsWithCommonStop.twconfig  0.00  967483  26395.54137  Day
Fills  2021-07-13 10:58:32.002  SILU21  Trading Evaluator order update (Filled). Info: Trade simulation fill. Bid: 26.250 Ask: 26.260 Last: 26.255. Text: Parent order. Tag: 2TargetsWithCommonStop.twconfig  26398  967486  Market  1  Sell      Filled  26.250  1  nikanikiforukgmailcom  Open    -2  967486.1      2TargetsWithCommonStop.twconfig  0.00  967486  26398.55408  Day
Fills  2021-07-13 14:02:51.002  SILU21  Trading Evaluator order update (Filled). Info: Trade simulation fill. Bid: 26.050 Ask: 26.055 Last: 26.060. Fill based on queue. Text: Attached order. Parent: 26398. Tag: 2TargetsWithCommonStop.twconfig  26399  967487  Limit  1  Buy  26.050    Filled  26.050  1  nikanikiforukgmailcom  Close  26398  -1  967487.1  26.270  26.050  2TargetsWithCommonStop.twconfig  0.00  967487  26399.97142  Day
Fills  2021-07-14 08:06:12.231  SILU21  Trading Evaluator order update (Filled). Info: Trade simulation fill. Bid: 26.355 Ask: 26.360 Last: 26.355. Text: Tag: 2TargetsWithCommonStop.twconfig  26433  968229  Market  1  Buy      Filled  26.360  1  nikanikiforukgmailcom  Close      968229.1  26.360  26.030  2TargetsWithCommonStop.twconfig  0.00  968229  26433.82926  Day
here's entry 2 lots, 1 exit by target and one i flattenned the next day when it went through my stop completely ignoring it. interesting that all of them are showed TIF Day while they're set to GTC and they definitely were still there after the day close. i still have stop and target orders lines on chart that were set yesterday and they survived market close twice already. one of them was filled at about 10pm yesterday so they are in fact GTC. here's log for those
Fills  2021-07-14 12:02:12.002  SILU21  Trading Evaluator order update (Filled). Info: Trade simulation fill. Bid: 26.210 Ask: 26.215 Last: 26.210. Text: Parent order. Tag: 2TargetsWithCommonStop.twconfig  26464  969217  Market  1  Buy      Filled  26.215  1  nikanikiforukgmailcom  Open    1  969217.1      2TargetsWithCommonStop.twconfig  0.00  969217  26464.40470  Day
Fills  2021-07-14 12:02:12.002  SILU21  Trading Evaluator order update (Filled). Info: Trade simulation fill. Bid: 26.210 Ask: 26.215 Last: 26.210. Text: Parent order. Tag: 2TargetsWithCommonStop.twconfig  26467  969220  Market  1  Buy      Filled  26.215  1  nikanikiforukgmailcom  Open    2  969220.1      2TargetsWithCommonStop.twconfig  0.00  969220  26467.81800  Day
Fills  2021-07-14 21:38:14.002  SILU21  Trading Evaluator order update (Filled). Info: Trade simulation fill. Bid: 26.390 Ask: 26.395 Last: 26.390. Text: Attached order. Parent: 26467. Tag: 2TargetsWithCommonStop.twconfig  26468  969221  Limit  1  Sell  26.390    Filled  26.390  1  nikanikiforukgmailcom  Close  26467  1  969221.1  26.390  26.170  2TargetsWithCommonStop.twconfig  0.00  969221  26468.91300  Day
[2021-07-16 06:51:39]
Good.
We are fairly sure we have identified the reason why the orders did not fill when expected. We are resolving this.
We are looking into the issue of the orders not expiring. But that is probably most likely related.
