Date/Time: Sun, 19 May 2024 01:41:46 +0000
question on chart
View Count: 570
[2019-11-05 21:06:55] |
User183272 - Posts: 13 |
http://www.sierrachart.com/image.php?Image=157298790498.png what you see is a volume profile on a numbers bar chart -how do I shrink the volume profile? -how do I align the volume profile to the right of the chart so I can see the numbers bar? Thanks! |
[2019-11-05 22:44:34] |
To control how far the Volume Profile extends, refer to the following setting and the one after it: Volume By Price Study: Maximum Volume Bar Width Type To align the profile to the far right, refer to the following: Volume By Price Study: Align to Far Right Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
