Date/Time: Sat, 18 May 2024 22:03:34 +0000
[Programming Help] - Working with sc.GraphDrawType
View Count: 701
[2019-11-05 17:06:38] |
brenanstewart - Posts: 28 |
I programmed a study and currently have it using sc.Subgraph[0].DrawStyle = DRAWSTYLE_LINE. Instead of drawing a line, I want it to plot candlesticks. It looks like in order to do this I need to use sc.GraphDrawType = GDT_CANDLESTICK. I've been referencing this page: ACSIL Interface Members - Variables and Arrays: sc.GraphDrawType I haven't been able to get it to work using sc.Subgraph[SC_OPEN][], sc.Subgraph[SC_HIGH][], sc.Subgraph[SC_LOW][], sc.Subgraph[SC_LAST][]. Is there an example study I can look at that uses GDT_CANDLESTICK (or something similar) for the Graph Draw Type? |
[2019-11-05 17:47:27] |
Ackin - Posts: 1865 |
scsf_AskBidVolumeDifferenceBars scsf_UpDownVolumeDifferenceBars scsf_CumulativeDeltaBarsVolume scsf_CumulativeDeltaBarsTicks scsf_CumulativeDeltaBarsTickVolume in the /ACS_Source folder in the folder Sierra Chart is installed -> Studies8.cpp To the extent there are any examples, they would be in the /ACS_Source folder that is included with your Sierra Chart install. Refer to the information here for how to search through those files for potential example programs:
How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies |
