Date/Time: Sun, 19 May 2024 02:33:41 +0000
filling area between two study subgraphs
View Count: 823
[2019-11-05 16:40:41] |
User57210 - Posts: 121 |
This documentation does not appear to be correct: Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study Specifically, once you get to step #8 in the documentation. Additionally, there only ever seems to be one single 'study subgraph to reference' in the Study Subgraph Reference study, while the documentation frequently refers to setting things up for 'each subgraph as you require'. |
[2019-11-05 18:28:17] |
You need to use the "Study Subgraphs Reference" study. Note the additional 's' on the end of Subgraphs.
[2019-11-06 02:41:45] |
We did update step 8 regarding the names of the Subgraphs.
