Date/Time: Sun, 19 May 2024 02:33:48 +0000
P&L is very wrong today
View Count: 554
[2019-11-05 16:11:37] |
User213661 - Posts: 2 |
Good day, I clearly took a short on NQ at 10:15 99.50 and bought back at 97.50 and DOM shows -525? chart and broker confirms this was a winner but shows a loss of -525? also reflected in my trade activity. Any ideas? Thank you |
[2019-11-05 16:16:59] |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-05 16:50:27] |
Sorry, we do not provide further help. The documentation is quite clear. The responsibility is on you to understand the documentation and to resolve the problem to extent you can if possible. You have access to the data and only you can answer why there is a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-05 16:51:13
