Date/Time: Sun, 19 May 2024 04:11:03 +0000
CBOE for Denali Data
View Count: 712
[2019-11-05 05:58:16] |
User455308 - Posts: 19 |
I understand that Denali Data Exchanges do not include CBOE exchange instruments. This will mean that all VIX related futures and indexes is not available for plotting. Is there a way to subscribe via an add-on or do you plan to package them in the bundle?
[2019-11-05 13:28:52] |
You instead need to use this data feed for CBOE indices and futures: Sierra Chart Exchange Data Feed You can start with it next month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-05 13:34:58
[2019-11-06 05:58:33] |
I will stick with Denali. I am just suggesting that you add this option for Denali Data. Thanks.
[2019-11-06 17:20:32] |
We cannot do that. It is cost prohibitive.
