Date/Time: Mon, 13 Jul 2026 13:54:31 +0000
add Trade Symbol to Symbol Settings
View Count: 1977
| [2019-11-03 10:34:24] |
| Cavalry3162 - Posts: 523 |
Hello SC, please add the functionality which is already there in "Chart Settings" into the "Symbol Settings" to make it symbol dependent. as it is right now a chart can have a trade symbol set but when you switch the chart symbol via a watchlist the setting is useless / gone. Having it in the Symbol Settings would remedy this issue. thanks, Andreas |
| [2019-11-03 14:47:05] |
This is already supported in the Global Symbol Settings. The particular setting is "Trade and Current Quote Symbol".
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-11-03 14:47:29
| [2019-11-03 15:44:20] |
ah, "Trade/Quote Symbol" roger that.. |
| [2019-11-04 09:24:53] |
if i set this for a stock symbol and then move to a diff symbol via a watchlist which does not have such a symbol set it does not reset the chart to an "empty" trade symbol. so i add up with the new symbol for charting but the "old" symbol for trading.. i'd consider that as a bug. please reset the trade symbol after a symbol change via watchlist. thank you |
| [2019-11-09 09:46:05] |
SC? any comments?
| [2019-11-13 00:45:20] |
| User379468 - Posts: 508 |
i'd consider that as a bug. please reset the trade symbol after a symbol change via watchlist. Experienced this, placed live order on ES intending to trade MES contracts, getting filled on M2K instead. Extremely confusing, realized what happened afterwards having read your problem report, was previous trade symbol on that chart, switched through watchlist. |
| [2019-11-17 04:10:18] |
It used to work like you are describing but then it creates a problem where the Trade and Current Quote Symbol under certain conditions gets cleared unexpectedly. So we solved that problem. You are responsible for knowing how you have set that setting. And to clear it as needed. After all it is displayed at the top left of a chart, by default in the symbol display. Be sure to add that field: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-11-17 06:15:38] |
As it is right now it’s useless and makes no sense.. why on Earth would one leave a trade symbol while changing the chart symbol!?
