Date/Time: Sat, 18 May 2024 14:59:54 +0000
Diag Delta in Calculated Numbers
View Count: 984
[2019-11-01 14:53:17] |
User135370 - Posts: 160 |
Hi Is there a way that I can see the difference between the Diagnol Positive and the Negative Delta in the Calculated Numbers rather than having to look at both to see which one is higher and crunch the difference in my head, how can I do the calculation and display it so it is easy for me to see. I have attached a screenshot so you can see what I mean. |
Diagonal Delta.JPG / V - Attached On 2019-11-01 14:53:03 UTC - Size: 34.19 KB - 285 views |
[2019-11-01 15:53:09] |
User907968 - Posts: 804 |
I might be being slow here but.... If you sum the diagonal +ve delta and the diagonal -ve delta, then the difference between the two values is simply delta. |
[2019-11-01 16:28:53] |
User907968 is correct. Therefore, to see the difference just set the Ask Volume Bid Volume Difference Subgraph to be displayed. Refer to the following: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
