Date/Time: Tue, 07 May 2024 12:38:56 +0000
changing from AMP-Rithmic data feed to Sierra's (non-professional)
View Count: 2992
[2019-12-02 13:29:32] |
No you cannot pay for Sierra Chart through Interactive Brokers. You need to contact AMP now and tell them that you do not want to pay for Sierra Chart through them. This is essential otherwise you are going to continue to get billed. And you have to start paying next month for Sierra Chart directly. We have removed your Sierra Chart account from being associated with AMP. You now need to connect it to Interactive Brokers as explained here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees (Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-02 13:30:01
[2019-12-02 13:39:55] |
User912279 - Posts: 102 |
It was my preferred way to pay for Sierra as well as the data feed directly thru Sierra, so that is not a problem, although as I said above: the plan was to pay with the remaining balance at my AMP account for the next few months. Can you activate for now my access to the data feed? I am contacting AMP in the mean time. |
[2019-12-02 13:41:54] |
In regards to the above, you need to do the following which is required by the CME:You now need to connect Sierra Chart to Interactive Brokers as explained here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees (Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-02 13:42:11
[2019-12-02 13:51:31] |
I have actually tried that today already, but that was before our conversation here. Now IT WORKED! Thank you. So my next step is to discontinue with AMP paying for Sierra, right? Can you please take from AMP Sierra's December (and perhaps even January) monthly subscription fee now? |
[2019-12-02 15:11:04] |
I have I think managed to arrange with AMP that I will be able to keep paying for Sierra SC5 for the next months. I just received credentials to (I think) enable me logging in, so that my data feed is enabled. I believe this is what I need to use once a month in order to enable my data feed. Am I correct? After these few months then we can arrange "migrating" my SC5 monthly subscription directly to Sierra. |
[2019-12-02 21:05:03] |
I have tried to log in with the new password now at market close, but Sierra says it's not valid. Or is it only valid from tomorrow? Or is this new password supposed to be used next month when I eventually run into this problem again early January? |
[2019-12-03 00:18:07] |
What new password are you referring to? What is it for. Where did it come from?
[2019-12-03 11:39:08] |
From support@sierracharts.com @9.59 EST and at the same time from tradedestampfutures.com. Also: AMP has charged the November SC5 from the account, leaving there $50 for January and February, after which I will migrate paymnt for all subscriptions directly to my Sierra Account. May I assume that this new password is just a technicality (as it is not working, but is probably for the purpose paying thru AMP for my SC5) and I shold just keep using my original password? |
[2019-12-03 18:33:44] |
This is still not clear for us. If you are referring to a different Sierra Chart Account name and password, you can use those by following the instructions here: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-03 18:52:14] |
Should I forward you the mail back to support?
[2019-12-04 00:19:51] |
Well are you having any current issue at this time?
[2019-12-04 02:19:32] |
No issues, thank you. Perhaps this was the only way AMP could arrange the SC5 payments thru them, while Sierra directly charges the data feed. (?) I know I can count on you to help me thru the next two months' payments before I can migrate then this last part to Sierra as well. As for the quality of the Denali data feed; I kept on monitoring the data delay during times of increased volatility and these last weeks I noticed a slight (maybe a second long) delay in times of volatility on ES prices displayed in Sierra compared to my Interactive Brokers. So, unfortunately I will have to experiment with lowering my Market Depth Data, but I as you described and see how that improves the delay. Of course this delay is no-way near as debilitating as Rithmic's 10-30 second delay used to be! I will keep you updated. And thank you again for your help and hope the payments will be seamless from here on. |
[2019-12-09 14:00:32] |
Dear Sir, Again, I don't have live data feed from, Denali. Just like last Monday. I have logged in also with my Interactive Brokers credentials, but it didn't change anything. Could you please release the data feed? |
[2019-12-09 14:46:49] |
Thank you. The data feed just got reestablished.
[2019-12-10 21:28:13] |
Dear Sirs, Last year I had a question under Rithmic data feed about resetting the pulling/stacking columns on the DOM. You said you were working on it, in order to make it easier with a menu command, instead of just reconnecting the data feed. I wonder, now that I have Denali data feed. Is this resetting already built in and possible? I came to the conclusion that resetting at least in the open would improve the usefulness of the DOM significantly. What's more: if it was possible to define 4-5 times of the day when it should restart the counter would make this functionality really perfect. Meanwhile I am just restarting the connection every time I need "new visibility", although this sometimes results in interruption in my Denali feed, requiring more restarts. See my other thread about it here: Rithmic DOM pulling-stacking restart Thank you, Date Time Of Last Edit: 2019-12-10 21:32:46
[2019-12-10 23:51:45] |
Sierra_Chart Engineering - Posts: 14253 |
We will add the command to reset Market Depth Pulling and Stacking.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-10 23:55:00
[2019-12-11 23:19:28] |
Dear Sirs, since you apparently solved my Denali data feed problem recurring this Monday, I had to restart my connection every day after the OverNight open at least once and even log in to my Interactive-Brokers credentials with Sierra to make the data feed start again. But now even that doesn't seem to help. Could you please look into this? I have asked on Monday for help from Raymond Matthew directly, too, but he wasn't the one who solve the issue on Monday. Was it you or did the issue just resolve itself then as well? |
[2019-12-12 10:22:26] |
Dear Sirs, After 12 hours the Denali feed still doesn't work. Could this still be connected to the fact that I have work with Interactive Brokers and not AMP? Could you please update in your system my Interactive Brokers account (*)? Date Time Of Last Edit: 2019-12-12 23:03:00
[2019-12-12 23:02:43] |
Tell us one of the symbols you are having a problem with and follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-12 23:04:22
[2019-12-12 23:16:05] |
On your previous message you suggested that my issue could arise because I am perhaps not using a symbol that is under the CME package: The case is nothing of the sort as all thru these months I was only talking about one single Index Futures, the ES mini (Now ESZ19) that I have been using and am using still. Are you saying that it wasn't you who released my data feed earlier today as well as on Monday this week? That the issue resolved itself every time after all those hours? |
[2019-12-13 07:18:07] |
Software version: 1991 64-bit | 2019-12-13 02:13:57.409 Usage end date: 2019-12-31 | 2019-12-13 02:13:57.410 Enabled for: Advanced Features 2. | 2019-12-13 02:13:57.410 Enabled for: Sierra Chart Historical Data Service. | 2019-12-13 02:13:57.410 Enabled for: Denali Real-Time Exchange Data Feed. | 2019-12-13 02:13:57.410 Enabled for exchange2: CME | 2019-12-13 02:13:57.410 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-12-13 02:13:57.410 Current selected Data/Trading service: SC Data - All Services | 2019-12-13 02:13:57.410 Custom symbol settings values: disabled | 2019-12-13 02:13:57.410 Chart Update Interval: 350 | 2019-12-13 02:13:57.410 Intraday Data Storage Time Unit: 0 | 2019-12-13 02:13:57.410 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-12-13 02:13:57.410 2019-12-13 08:13:57 Local computer time | 2019-12-13 02:13:57.410 2019-12-13 07:13:57 Local computer time in UTC | 2019-12-13 02:13:57.410 2019-12-13 02:13:57 Local computer time in SC Time Zone | 2019-12-13 02:13:57.410 2019-12-13 06:50:46 Server time in UTC | 2019-12-13 02:13:57.410 Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-12-13 02:13:57.410 Program path: D:\SierraChart\ | 2019-12-13 02:13:57.410 Data Files path: D:\SierraChart\Data\ | 2019-12-13 02:13:57.410 OS Version Number: 10.0 | 2019-12-13 02:13:57.410 Locale Setting: C | 2019-12-13 02:13:57.410 DLLs: DepthSum_64.dll, Frequency_Spike_Alert_64.dll, Historical_Intersections_64.dll, L3A_Dev_64.dll, PnV_Overlay_64.dll, Precision_Collection.dll, Precision_Collection_64.dll, RelativeTVOL_64.dll, ResettingVWAP_64.dll, SpreadDefence_64.dll, Trendicator-SP_64.dll, Trendicator2_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VolumeSegments_64.dll | 2019-12-13 02:13:57.410 File >> Disconnect selected. | 2019-12-13 02:13:59.782 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:13:59.806 SC DTC Data with Market Depth | Disconnected from the server. | 2019-12-13 02:13:59.806 SC Data - All Services | Disconnected. | 2019-12-13 02:13:59.806 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-12-13 02:13:59.925 DTC Client socket (1) | Closed. | 2019-12-13 02:13:59.925 SC Data - All Services | Connected to data server. | 2019-12-13 02:14:00.221 Triggering next historical data download in queue. | 2019-12-13 02:14:00.221 Triggering next historical data download in queue. | 2019-12-13 02:14:00.221 Triggering next historical data download in queue. | 2019-12-13 02:14:00.221 Triggering next historical data download in queue. | 2019-12-13 02:14:00.221 SC DTC Data with Market Depth | Starting real-time market data updates for: PVOL-NYSE. ID: 1 Service code: statscalc | 2019-12-13 02:14:00.221 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2019-12-13 02:14:00.221 SC DTC Data with Market Depth | Requesting security definition data for: PVOL-NYSE. ID: 1 | 2019-12-13 02:14:00.221 SC DTC Data with Market Depth | Starting real-time market data updates for: PVOL-SP. ID: 2 Service code: statscalc | 2019-12-13 02:14:00.221 SC DTC Data with Market Depth | Requesting security definition data for: PVOL-SP. ID: 2 | 2019-12-13 02:14:00.221 DTC Client socket (1) | Creating socket. | 2019-12-13 02:14:00.222 DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2019-12-13 02:14:00.222 SC DTC Data with Market Depth | Starting real-time market data updates for: DECL-NYSE. ID: 3 Service code: statscalc | 2019-12-13 02:14:00.244 SC DTC Data with Market Depth | Requesting security definition data for: DECL-NYSE. ID: 3 | 2019-12-13 02:14:00.244 Added historical Intraday data request for DECL-NYSE to the queue. | 2019-12-13 02:14:00.244 Intraday data recording state for symbol DECL-NYSE is set to download 'Pending'. | 2019-12-13 02:14:00.244 ADV-NYSE[M] 1 Min #25 | Started historical data download for additional symbol DECL-NYSE. Download ID: 63 | 2019-12-13 02:14:00.244 SC DTC Data with Market Depth | Starting real-time market data updates for: DECL-SP. ID: 4 Service code: statscalc | 2019-12-13 02:14:00.244 SC DTC Data with Market Depth | Requesting security definition data for: DECL-SP. ID: 4 | 2019-12-13 02:14:00.244 Added historical Intraday data request for DECL-SP to the queue. | 2019-12-13 02:14:00.244 Intraday data recording state for symbol DECL-SP is set to download 'Pending'. | 2019-12-13 02:14:00.244 ADV-SP[M] 1 Min #36 | Started historical data download for additional symbol DECL-SP. Download ID: 64 | 2019-12-13 02:14:00.244 Delaying start of download for DECL-NYSE | 2019-12-13 02:14:00.245 Mapping ESZ19 to ESZ19. Service code: cme | 2019-12-13 02:14:00.279 SC Data - All Services | Starting real-time market data updates for: ESZ19 (ESZ19). ID: 5 Service code: cme | 2019-12-13 02:14:00.279 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2019-12-13 02:14:00.279 SC Data - All Services | Requesting security definition data for: ESZ19 (ESZ19). ID: 5 | 2019-12-13 02:14:00.279 Added historical Intraday data request for ESZ19 to the queue. | 2019-12-13 02:14:00.279 Intraday data recording state for symbol ESZ19 is set to download 'Pending'. | 2019-12-13 02:14:00.279 Triggering next historical data download in queue. | 2019-12-13 02:14:00.279 DTC Client socket (2) | Creating socket. | 2019-12-13 02:14:00.280 DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2019-12-13 02:14:00.280 SC DTC Data with Market Depth | Connected to server. | 2019-12-13 02:14:00.568 SC DTC Data with Market Depth | Starting socket receive thread. | 2019-12-13 02:14:00.568 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2019-12-13 02:14:00.568 SC Data - All Services | Connected to server. | 2019-12-13 02:14:00.568 SC Data - All Services | Starting socket receive thread. | 2019-12-13 02:14:00.568 SC Data - All Services | Sending encoding request to server: Binary VLS | 2019-12-13 02:14:00.568 SC Data - All Services | Setting DTC encoding to Binary VLS | 2019-12-13 02:14:00.810 SC Data - All Services | Sending logon request message. | 2019-12-13 02:14:00.810 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2019-12-13 02:14:00.810 SC DTC Data with Market Depth | Sending logon request message. | 2019-12-13 02:14:00.810 SC Data - All Services | Received logon response. | 2019-12-13 02:14:00.975 SC Data - All Services | Server Name: SC Real-Time Server. | 2019-12-13 02:14:00.975 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2019-12-13 02:14:00.975 SC Data - All Services | Connection error: Unsupported client version.. | 2019-12-13 02:14:00.975 * SC Data - All Services | Disconnected from the server. | 2019-12-13 02:14:00.975 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:14:00.975 DTC Client socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:14:01.099 DTC Client socket (2) | Closed. | 2019-12-13 02:14:01.099 SC DTC Data with Market Depth | Received logon response. | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Successfully connected. | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Trading is not supported. | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DECL-NYSE | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DECL-SP | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: PVOL-NYSE | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: PVOL-SP | 2019-12-13 02:14:01.462 SC DTC Data with Market Depth | Received security definition for symbol DECL-NYSE | 2019-12-13 02:14:01.644 SC DTC Data with Market Depth | Received security definition for symbol DECL-SP | 2019-12-13 02:14:01.645 SC DTC Data with Market Depth | Received security definition for symbol PVOL-NYSE | 2019-12-13 02:14:01.645 SC DTC Data with Market Depth | Received security definition for symbol PVOL-SP | 2019-12-13 02:14:01.645 SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL-SP. ID: 6 Service code: statscalc | 2019-12-13 02:14:01.651 SC DTC Data with Market Depth | Requesting security definition data for: NVOL-SP. ID: 6 | 2019-12-13 02:14:01.651 Added historical Intraday data request for NVOL-SP to the queue. | 2019-12-13 02:14:01.651 Intraday data recording state for symbol NVOL-SP is set to download 'Pending'. | 2019-12-13 02:14:01.651 Triggering next historical data download in queue. | 2019-12-13 02:14:01.651 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-NYSE. ID: 7 Service code: statscalc | 2019-12-13 02:14:01.691 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-NYSE. ID: 7 | 2019-12-13 02:14:01.691 Added historical Intraday data request for TRIN-NYSE to the queue. | 2019-12-13 02:14:01.691 Intraday data recording state for symbol TRIN-NYSE is set to download 'Pending'. | 2019-12-13 02:14:01.691 Triggering next historical data download in queue. | 2019-12-13 02:14:01.691 SC DTC Data with Market Depth | Starting real-time market data updates for: NVOL-NYSE. ID: 8 Service code: statscalc | 2019-12-13 02:14:01.696 SC DTC Data with Market Depth | Requesting security definition data for: NVOL-NYSE. ID: 8 | 2019-12-13 02:14:01.696 Added historical Intraday data request for NVOL-NYSE to the queue. | 2019-12-13 02:14:01.696 Intraday data recording state for symbol NVOL-NYSE is set to download 'Pending'. | 2019-12-13 02:14:01.696 Triggering next historical data download in queue. | 2019-12-13 02:14:01.696 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-SP. ID: 9 Service code: statscalc | 2019-12-13 02:14:01.761 SC DTC Data with Market Depth | Requesting security definition data for: ADV-SP. ID: 9 | 2019-12-13 02:14:01.761 Added historical Intraday data request for ADV-SP to the queue. | 2019-12-13 02:14:01.762 Intraday data recording state for symbol ADV-SP is set to download 'Pending'. | 2019-12-13 02:14:01.762 Triggering next historical data download in queue. | 2019-12-13 02:14:01.762 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 10 Service code: statscalc | 2019-12-13 02:14:01.764 SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 10 | 2019-12-13 02:14:01.764 Added historical Intraday data request for NISS-NYSE to the queue. | 2019-12-13 02:14:01.764 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2019-12-13 02:14:01.764 Triggering next historical data download in queue. | 2019-12-13 02:14:01.764 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 11 Service code: statscalc | 2019-12-13 02:14:01.769 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 11 | 2019-12-13 02:14:01.769 Added historical Intraday data request for TICK-NYSE to the queue. | 2019-12-13 02:14:01.769 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2019-12-13 02:14:01.769 Triggering next historical data download in queue. | 2019-12-13 02:14:01.769 SC DTC Data with Market Depth | Starting real-time market data updates for: TRIN-SP. ID: 12 Service code: statscalc | 2019-12-13 02:14:01.772 SC DTC Data with Market Depth | Requesting security definition data for: TRIN-SP. ID: 12 | 2019-12-13 02:14:01.772 Added historical Intraday data request for TRIN-SP to the queue. | 2019-12-13 02:14:01.772 Intraday data recording state for symbol TRIN-SP is set to download 'Pending'. | 2019-12-13 02:14:01.772 Triggering next historical data download in queue. | 2019-12-13 02:14:01.772 SC DTC Data with Market Depth | Starting real-time market data updates for: TVOL-NYSE. ID: 13 Service code: statscalc | 2019-12-13 02:14:01.907 SC DTC Data with Market Depth | Requesting security definition data for: TVOL-NYSE. ID: 13 | 2019-12-13 02:14:01.907 Added historical Intraday data request for TVOL-NYSE to the queue. | 2019-12-13 02:14:01.907 Intraday data recording state for symbol TVOL-NYSE is set to download 'Pending'. | 2019-12-13 02:14:01.907 Triggering next historical data download in queue. | 2019-12-13 02:14:01.907 SC DTC Data with Market Depth | Received security definition for symbol NVOL-SP | 2019-12-13 02:14:01.908 SC DTC Data with Market Depth | Received security definition for symbol TRIN-NYSE | 2019-12-13 02:14:01.908 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-SP. ID: 14 Service code: statscalc | 2019-12-13 02:14:01.942 SC DTC Data with Market Depth | Requesting security definition data for: TICK-SP. ID: 14 | 2019-12-13 02:14:01.942 Added historical Intraday data request for TICK-SP to the queue. | 2019-12-13 02:14:01.942 Intraday data recording state for symbol TICK-SP is set to download 'Pending'. | 2019-12-13 02:14:01.942 Triggering next historical data download in queue. | 2019-12-13 02:14:01.942 SC DTC Data with Market Depth | Received security definition for symbol NVOL-NYSE | 2019-12-13 02:14:01.974 SC DTC Data with Market Depth | Received security definition for symbol ADV-SP | 2019-12-13 02:14:01.974 SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2019-12-13 02:14:01.974 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2019-12-13 02:14:02.072 SC DTC Data with Market Depth | Received security definition for symbol TRIN-SP | 2019-12-13 02:14:02.072 SC DTC Data with Market Depth | Received security definition for symbol TVOL-NYSE | 2019-12-13 02:14:02.072 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-SP. ID: 15 Service code: statscalc | 2019-12-13 02:14:02.101 SC DTC Data with Market Depth | Requesting security definition data for: NISS-SP. ID: 15 | 2019-12-13 02:14:02.101 Added historical Intraday data request for NISS-SP to the queue. | 2019-12-13 02:14:02.101 Intraday data recording state for symbol NISS-SP is set to download 'Pending'. | 2019-12-13 02:14:02.101 Triggering next historical data download in queue. | 2019-12-13 02:14:02.101 SC DTC Data with Market Depth | Received security definition for symbol TICK-SP | 2019-12-13 02:14:02.178 SC DTC Data with Market Depth | Starting real-time market data updates for: ADV-NYSE. ID: 16 Service code: statscalc | 2019-12-13 02:14:02.222 SC DTC Data with Market Depth | Requesting security definition data for: ADV-NYSE. ID: 16 | 2019-12-13 02:14:02.222 Added historical Intraday data request for ADV-NYSE to the queue. | 2019-12-13 02:14:02.222 Intraday data recording state for symbol ADV-NYSE is set to download 'Pending'. | 2019-12-13 02:14:02.222 Triggering next historical data download in queue. | 2019-12-13 02:14:02.222 SC DTC Data with Market Depth | Received security definition for symbol NISS-SP | 2019-12-13 02:14:02.264 Requesting market depth updates for: ESZ19 if supported. | 2019-12-13 02:14:02.434 Separate subscription for market depth updates not supported. ESZ19 | 2019-12-13 02:14:02.434 SC DTC Data with Market Depth | Received security definition for symbol ADV-NYSE | 2019-12-13 02:14:02.467 HD Request # 63 | Downloading Intraday chart data for DECL-NYSE to the file DECL-NYSE.scid. Service: statscalc | 2019-12-13 02:14:06.817 HD Request # 63 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:14:06.817 HD Request # 63 | Using server: ds3.sierracharts.com port 10150 | 2019-12-13 02:14:06.817 Socket (2) | Creating socket. | 2019-12-13 02:14:06.817 Socket (2) | Connecting to IP: 65.182.172.42. | 2019-12-13 02:14:06.817 HD Request # 63 | Setting DTC encoding to Binary VLS | 2019-12-13 02:14:07.078 HD Request # 63 | Sending historical data logon request message. | 2019-12-13 02:14:07.078 HD Request # 63 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: DECL-NYSE | 2019-12-13 02:14:07.207 HD Request # 63 | Decompressing data. | 2019-12-13 02:14:07.336 HD Request # 63 | Receiving Intraday data for DECL-NYSE starting at 2019-12-12 20:00:03 | 2019-12-13 02:14:07.336 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:14:07.336 Historical data download thread signaled to stop. | 2019-12-13 02:14:07.341 HD Request # 63 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for DECL-NYSE | 2019-12-13 02:14:07.342 HD Request # 63 | Completion time: 1s | 2019-12-13 02:14:07.342 HD Request # 63 | Intraday data download complete for DECL-NYSE. Unique request ID: 63 | 2019-12-13 02:14:07.342 Removed historical data download ID 63 | 2019-12-13 02:14:07.342 Real-time Intraday chart data file updates started for DECL-NYSE | 2019-12-13 02:14:07.342 Intraday chart data file opened for DECL-NYSE | 2019-12-13 02:14:07.342 ADV-NYSE[M] 1 Min #25 | Historical data download for additional symbol DECL-NYSE with ID 63 has completed. | 2019-12-13 02:14:07.342 Triggering next historical data download in queue. | 2019-12-13 02:14:07.342 HD Request # 64 | Downloading Intraday chart data for DECL-SP to the file DECL-SP.scid. Service: statscalc | 2019-12-13 02:14:07.342 HD Request # 64 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:14:07.342 HD Request # 64 | Using server: ds4.sierracharts.com port 10149 | 2019-12-13 02:14:07.342 Socket (3) | Creating socket. | 2019-12-13 02:14:07.342 Socket (3) | Connecting to IP: 192.81.56.146. | 2019-12-13 02:14:07.342 ADV-NYSE[M] 1 Min #25 | Reloading chart. | 2019-12-13 02:14:07.383 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:14:07.465 Socket (2) | Closed. | 2019-12-13 02:14:07.465 HD Request # 64 | Setting DTC encoding to Binary VLS | 2019-12-13 02:14:07.609 HD Request # 64 | Sending historical data logon request message. | 2019-12-13 02:14:07.609 Chart #31 has tagged chart #25 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:14:07.652 HD Request # 64 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: DECL-SP | 2019-12-13 02:14:08.224 + Loading additional symbol data. | 2019-12-13 02:14:08.285 HD Request # 64 | Decompressing data. | 2019-12-13 02:14:08.354 HD Request # 64 | Receiving Intraday data for DECL-SP starting at 2019-12-12 20:00:03 | 2019-12-13 02:14:08.355 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:14:08.355 Historical data download thread signaled to stop. | 2019-12-13 02:14:08.355 HD Request # 64 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for DECL-SP | 2019-12-13 02:14:08.355 HD Request # 64 | Completion time: 1s | 2019-12-13 02:14:08.355 HD Request # 64 | Intraday data download complete for DECL-SP. Unique request ID: 64 | 2019-12-13 02:14:08.355 Removed historical data download ID 64 | 2019-12-13 02:14:08.355 Real-time Intraday chart data file updates started for DECL-SP | 2019-12-13 02:14:08.355 Intraday chart data file opened for DECL-SP | 2019-12-13 02:14:08.355 ADV-SP[M] 1 Min #36 | Historical data download for additional symbol DECL-SP with ID 64 has completed. | 2019-12-13 02:14:08.355 Triggering next historical data download in queue. | 2019-12-13 02:14:08.355 Delaying start of download for ESZ19 | 2019-12-13 02:14:08.355 ADV-SP[M] 1 Min #36 | Reloading chart. | 2019-12-13 02:14:08.369 Chart #59 has tagged chart #36 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:14:08.381 Socket (3) | Socket gracefully closed by remote side. | 2019-12-13 02:14:08.486 Socket (3) | Closed. | 2019-12-13 02:14:08.486 Chart #25 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:14:08.786 ESZ19 [C][M] 5 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:14:09.090 + Loading additional symbol data. | 2019-12-13 02:14:09.134 Chart #36 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:14:09.554 ESZ19 [C][M] 5 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:14:09.806 HD Request # 65 | Downloading Intraday chart data for ESZ19 to the file ESZ19.scid. Service: cme | 2019-12-13 02:15:01.818 HD Request # 65 | Download start date-time: 2019-12-13 02:11:03.000 | 2019-12-13 02:15:01.818 HD Request # 65 | Using server: ds21.sierracharts.com port 10150 | 2019-12-13 02:15:01.818 Socket (2) | Creating socket. | 2019-12-13 02:15:01.818 Socket (2) | Connecting to IP: 216.1.90.129. | 2019-12-13 02:15:01.818 HD Request # 65 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:02.071 HD Request # 65 | Sending historical data logon request message. | 2019-12-13 02:15:02.071 HD Request # 65 | Requesting Intraday data. Start date-time: 2019-12-13 02:11:03. Record interval: 0. Symbol: ESZ19 | 2019-12-13 02:15:02.647 HD Request # 65 | Decompressing data. | 2019-12-13 02:15:02.771 HD Request # 65 | Receiving Intraday data for ESZ19 starting at 2019-12-13 02:11:03 | 2019-12-13 02:15:02.773 HD Request # 65 | Timestamp of first Intraday data file record written: 2019-12-13 02:11:14 | 2019-12-13 02:15:02.774 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:02.774 Historical data download thread signaled to stop. | 2019-12-13 02:15:02.809 HD Request # 65 | Received 726 records from 2019-12-13 02:11:03.000 to 2019-12-13 02:14:57.007 (3.9 minutes) and wrote 724 records for ESZ19 | 2019-12-13 02:15:02.810 HD Request # 65 | Completion time: 0s | 2019-12-13 02:15:02.817 HD Request # 65 | Intraday data download complete for ESZ19. Unique request ID: 65 | 2019-12-13 02:15:02.817 Removed historical data download ID 65 | 2019-12-13 02:15:02.817 Real-time Intraday chart data file updates started for ESZ19 | 2019-12-13 02:15:02.817 Intraday chart data file opened for ESZ19 | 2019-12-13 02:15:02.817 Triggering next historical data download in queue. | 2019-12-13 02:15:02.817 HD Request # 66 | Downloading Intraday chart data for NVOL-SP to the file NVOL-SP.scid. Service: statscalc | 2019-12-13 02:15:02.817 HD Request # 66 | Download start date-time: 2019-12-12 16:30:00.000 | 2019-12-13 02:15:02.817 HD Request # 66 | Using server: ds3.sierracharts.com port 10149 | 2019-12-13 02:15:02.817 Socket (3) | Creating socket. | 2019-12-13 02:15:02.817 Socket (3) | Connecting to IP: 65.182.172.42. | 2019-12-13 02:15:02.817 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:15:02.898 Socket (2) | Closed. | 2019-12-13 02:15:02.898 HD Request # 66 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:03.077 HD Request # 66 | Sending historical data logon request message. | 2019-12-13 02:15:03.077 HD Request # 66 | Requesting Intraday data. Start date-time: 2019-12-12 16:30:00. Record interval: 0. Symbol: NVOL-SP | 2019-12-13 02:15:03.199 HD Request # 66 | Decompressing data. | 2019-12-13 02:15:03.322 HD Request # 66 | Receiving Intraday data for NVOL-SP starting at 2019-12-12 16:30:00 | 2019-12-13 02:15:03.322 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:03.322 Historical data download thread signaled to stop. | 2019-12-13 02:15:03.365 HD Request # 66 | Received 1 record from 2019-12-12 16:30:00.000 to 2019-12-12 16:30:00.000 (0.0 seconds) and wrote 0 records for NVOL-SP | 2019-12-13 02:15:03.365 HD Request # 66 | Completion time: 1s | 2019-12-13 02:15:03.365 HD Request # 66 | Intraday data download complete for NVOL-SP. Unique request ID: 66 | 2019-12-13 02:15:03.365 Removed historical data download ID 66 | 2019-12-13 02:15:03.365 Real-time Intraday chart data file updates started for NVOL-SP | 2019-12-13 02:15:03.365 Intraday chart data file opened for NVOL-SP | 2019-12-13 02:15:03.365 Triggering next historical data download in queue. | 2019-12-13 02:15:03.365 HD Request # 67 | Downloading Intraday chart data for TRIN-NYSE to the file TRIN-NYSE.scid. Service: statscalc | 2019-12-13 02:15:03.365 HD Request # 67 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:15:03.365 HD Request # 67 | Using server: ds4.sierracharts.com port 10150 | 2019-12-13 02:15:03.366 Socket (2) | Creating socket. | 2019-12-13 02:15:03.366 Socket (2) | Connecting to IP: 192.81.56.146. | 2019-12-13 02:15:03.366 Socket (3) | Socket gracefully closed by remote side. | 2019-12-13 02:15:03.444 Socket (3) | Closed. | 2019-12-13 02:15:03.444 HD Request # 67 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:03.648 HD Request # 67 | Sending historical data logon request message. | 2019-12-13 02:15:03.648 Chart #40 has tagged chart #7 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.020 HD Request # 67 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: TRIN-NYSE | 2019-12-13 02:15:04.272 Chart #19 has tagged chart #18 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.313 Chart #38 has tagged chart #23 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.351 Chart #38 has tagged chart #26 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.351 Chart #38 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.351 Chart #38 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.351 Chart #38 has tagged chart #29 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.351 Chart #38 has tagged chart #39 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.351 ESZ19 [C][M] 10 Sec #39 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:04.383 HD Request # 67 | Decompressing data. | 2019-12-13 02:15:04.411 HD Request # 67 | Receiving Intraday data for TRIN-NYSE starting at 2019-12-12 20:00:03 | 2019-12-13 02:15:04.411 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:04.411 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:15:04.548 Socket (2) | Closed. | 2019-12-13 02:15:04.548 Historical data download thread signaled to stop. | 2019-12-13 02:15:05.021 HD Request # 67 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for TRIN-NYSE | 2019-12-13 02:15:05.021 HD Request # 67 | Completion time: 2s | 2019-12-13 02:15:05.021 HD Request # 67 | Intraday data download complete for TRIN-NYSE. Unique request ID: 67 | 2019-12-13 02:15:05.021 Removed historical data download ID 67 | 2019-12-13 02:15:05.021 Real-time Intraday chart data file updates started for TRIN-NYSE | 2019-12-13 02:15:05.021 Intraday chart data file opened for TRIN-NYSE | 2019-12-13 02:15:05.021 Triggering next historical data download in queue. | 2019-12-13 02:15:05.021 HD Request # 68 | Downloading Intraday chart data for NVOL-NYSE to the file NVOL-NYSE.scid. Service: statscalc | 2019-12-13 02:15:05.022 HD Request # 68 | Download start date-time: 2019-12-12 16:30:00.000 | 2019-12-13 02:15:05.022 HD Request # 68 | Using server: ds3.sierracharts.com port 10149 | 2019-12-13 02:15:05.022 Socket (2) | Creating socket. | 2019-12-13 02:15:05.022 Socket (2) | Connecting to IP: 65.182.172.42. | 2019-12-13 02:15:05.022 Chart #44 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.026 Chart #47 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.027 Chart #9 has tagged chart #20 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 Chart #9 has tagged chart #23 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 Chart #9 has tagged chart #26 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 Chart #9 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 Chart #9 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 Chart #9 has tagged chart #29 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 Chart #9 has tagged chart #3 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 Chart #9 has tagged chart #38 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 Chart #9 has tagged chart #8 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.161 HD Request # 68 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:05.279 HD Request # 68 | Sending historical data logon request message. | 2019-12-13 02:15:05.279 ESZ19 [C][M] 5 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.311 ESZ19 [C][M] 10 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.366 HD Request # 68 | Requesting Intraday data. Start date-time: 2019-12-12 16:30:00. Record interval: 0. Symbol: NVOL-NYSE | 2019-12-13 02:15:05.402 Chart #5 has tagged chart #7 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.406 ESZ19 [CB][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.453 HD Request # 68 | Decompressing data. | 2019-12-13 02:15:05.525 HD Request # 68 | Receiving Intraday data for NVOL-NYSE starting at 2019-12-12 16:30:00 | 2019-12-13 02:15:05.525 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:05.525 Chart #3 has tagged chart #7 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.529 Historical data download thread signaled to stop. | 2019-12-13 02:15:05.571 HD Request # 68 | Received 1 record from 2019-12-12 16:30:00.000 to 2019-12-12 16:30:00.000 (0.0 seconds) and wrote 0 records for NVOL-NYSE | 2019-12-13 02:15:05.571 HD Request # 68 | Completion time: 0s | 2019-12-13 02:15:05.571 HD Request # 68 | Intraday data download complete for NVOL-NYSE. Unique request ID: 68 | 2019-12-13 02:15:05.571 Removed historical data download ID 68 | 2019-12-13 02:15:05.571 Real-time Intraday chart data file updates started for NVOL-NYSE | 2019-12-13 02:15:05.571 Intraday chart data file opened for NVOL-NYSE | 2019-12-13 02:15:05.571 Triggering next historical data download in queue. | 2019-12-13 02:15:05.571 HD Request # 69 | Downloading Intraday chart data for ADV-SP to the file ADV-SP.scid. Service: statscalc | 2019-12-13 02:15:05.571 HD Request # 69 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:15:05.571 HD Request # 69 | Using server: ds4.sierracharts.com port 10150 | 2019-12-13 02:15:05.571 Socket (3) | Creating socket. | 2019-12-13 02:15:05.571 Socket (3) | Connecting to IP: 192.81.56.146. | 2019-12-13 02:15:05.571 Chart #16 has tagged chart #3 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.578 Chart #16 has tagged chart #7 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.578 Chart #21 has tagged chart #18 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.617 Chart #21 has tagged chart #3 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.617 Chart #21 has tagged chart #7 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.617 Chart #6 has tagged chart #3 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.620 Chart #6 has tagged chart #7 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.620 ESZ19 [CB][M] 5 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.622 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:15:05.655 Socket (2) | Closed. | 2019-12-13 02:15:05.655 ESZ19 [CB][M] #7 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.660 ESZ19 [CB][M] #8 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:05.742 HD Request # 69 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:05.838 HD Request # 69 | Sending historical data logon request message. | 2019-12-13 02:15:05.838 HD Request # 69 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: ADV-SP | 2019-12-13 02:15:05.968 HD Request # 69 | Decompressing data. | 2019-12-13 02:15:06.098 HD Request # 69 | Receiving Intraday data for ADV-SP starting at 2019-12-12 20:00:03 | 2019-12-13 02:15:06.098 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:06.099 Historical data download thread signaled to stop. | 2019-12-13 02:15:06.169 HD Request # 69 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for ADV-SP | 2019-12-13 02:15:06.169 HD Request # 69 | Completion time: 0s | 2019-12-13 02:15:06.170 HD Request # 69 | Intraday data download complete for ADV-SP. Unique request ID: 69 | 2019-12-13 02:15:06.170 Removed historical data download ID 69 | 2019-12-13 02:15:06.170 Real-time Intraday chart data file updates started for ADV-SP | 2019-12-13 02:15:06.170 Intraday chart data file opened for ADV-SP | 2019-12-13 02:15:06.170 Triggering next historical data download in queue. | 2019-12-13 02:15:06.170 HD Request # 70 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2019-12-13 02:15:06.170 HD Request # 70 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:15:06.170 HD Request # 70 | Using server: ds3.sierracharts.com port 10149 | 2019-12-13 02:15:06.170 Socket (2) | Creating socket. | 2019-12-13 02:15:06.170 Socket (2) | Connecting to IP: 65.182.172.42. | 2019-12-13 02:15:06.171 ESZ19 [CB][M] Renko 5t #23 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:06.174 ESZ19 [CB][M] 0.8 Range #26 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:06.226 Socket (3) | Socket gracefully closed by remote side. | 2019-12-13 02:15:06.231 Socket (3) | Closed. | 2019-12-13 02:15:06.231 Chart #36 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:06.282 ESZ19 [C][M] 30 Min #20 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:06.283 ESZ19 [C][M] 611 Trades #28 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:06.299 Chart #35 has tagged chart #38 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:06.408 Chart #37 has tagged chart #38 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:06.409 ESZ19 [C][M] 1 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:06.410 HD Request # 70 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:06.427 HD Request # 70 | Sending historical data logon request message. | 2019-12-13 02:15:06.427 HD Request # 70 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: NISS-NYSE | 2019-12-13 02:15:06.549 HD Request # 70 | Decompressing data. | 2019-12-13 02:15:06.673 HD Request # 70 | Receiving Intraday data for NISS-NYSE starting at 2019-12-12 20:00:03 | 2019-12-13 02:15:06.673 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:06.673 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:15:06.796 Socket (2) | Closed. | 2019-12-13 02:15:06.796 Chart #38 has tagged chart #23 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:07.332 Chart #38 has tagged chart #26 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:07.332 Chart #38 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:07.332 Chart #38 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:07.332 Chart #38 has tagged chart #29 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:07.332 Chart #38 has tagged chart #39 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:07.332 Historical data download thread signaled to stop. | 2019-12-13 02:15:07.357 HD Request # 70 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for NISS-NYSE | 2019-12-13 02:15:07.357 HD Request # 70 | Completion time: 1s | 2019-12-13 02:15:07.357 HD Request # 70 | Intraday data download complete for NISS-NYSE. Unique request ID: 70 | 2019-12-13 02:15:07.357 Removed historical data download ID 70 | 2019-12-13 02:15:07.357 Real-time Intraday chart data file updates started for NISS-NYSE | 2019-12-13 02:15:07.357 Intraday chart data file opened for NISS-NYSE | 2019-12-13 02:15:07.357 Triggering next historical data download in queue. | 2019-12-13 02:15:07.357 HD Request # 71 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2019-12-13 02:15:07.357 HD Request # 71 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:15:07.357 HD Request # 71 | Using server: ds4.sierracharts.com port 10150 | 2019-12-13 02:15:07.358 Socket (2) | Creating socket. | 2019-12-13 02:15:07.358 Socket (2) | Connecting to IP: 192.81.56.146. | 2019-12-13 02:15:07.358 ESZ19 [C][M] 10 Sec #39 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:07.362 HD Request # 71 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:07.623 HD Request # 71 | Sending historical data logon request message. | 2019-12-13 02:15:07.623 HD Request # 71 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: TICK-NYSE | 2019-12-13 02:15:07.752 HD Request # 71 | Decompressing data. | 2019-12-13 02:15:07.881 HD Request # 71 | Receiving Intraday data for TICK-NYSE starting at 2019-12-12 20:00:03 | 2019-12-13 02:15:07.881 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:07.881 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:15:08.011 Socket (2) | Closed. | 2019-12-13 02:15:08.011 Historical data download thread signaled to stop. | 2019-12-13 02:15:08.015 HD Request # 71 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2019-12-13 02:15:08.016 HD Request # 71 | Completion time: 0s | 2019-12-13 02:15:08.016 HD Request # 71 | Intraday data download complete for TICK-NYSE. Unique request ID: 71 | 2019-12-13 02:15:08.016 Removed historical data download ID 71 | 2019-12-13 02:15:08.016 Real-time Intraday chart data file updates started for TICK-NYSE | 2019-12-13 02:15:08.016 Intraday chart data file opened for TICK-NYSE | 2019-12-13 02:15:08.016 Triggering next historical data download in queue. | 2019-12-13 02:15:08.016 HD Request # 72 | Downloading Intraday chart data for TRIN-SP to the file TRIN-SP.scid. Service: statscalc | 2019-12-13 02:15:08.016 HD Request # 72 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:15:08.016 HD Request # 72 | Using server: ds3.sierracharts.com port 10149 | 2019-12-13 02:15:08.016 Socket (2) | Creating socket. | 2019-12-13 02:15:08.016 Socket (2) | Connecting to IP: 65.182.172.42. | 2019-12-13 02:15:08.016 Chart #42 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.019 Chart #45 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.020 Chart #46 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.021 Chart #48 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.023 Chart #1 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.031 Chart #11 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.033 ESZ19 [C][M] 5 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.034 ESZ19 [C][M] 10 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.095 Chart #41 has tagged chart #38 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.136 Chart #43 has tagged chart #38 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.138 ESZ19 [CB][M] #3 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.139 Chart #3 has tagged chart #7 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.220 HD Request # 72 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:08.265 HD Request # 72 | Sending historical data logon request message. | 2019-12-13 02:15:08.265 ESZ19 [CB][M] #7 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.267 ESZ19 [CB][M] Renko 5t #23 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.353 HD Request # 72 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: TRIN-SP | 2019-12-13 02:15:08.384 ESZ19 [CB][M] 0.8 Range #26 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.403 ESZ19 [C][M] 611 Trades #28 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.462 HD Request # 72 | Decompressing data. | 2019-12-13 02:15:08.503 HD Request # 72 | Receiving Intraday data for TRIN-SP starting at 2019-12-12 20:00:03 | 2019-12-13 02:15:08.504 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:08.504 Historical data download thread signaled to stop. | 2019-12-13 02:15:08.565 HD Request # 72 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for TRIN-SP | 2019-12-13 02:15:08.565 HD Request # 72 | Completion time: 0s | 2019-12-13 02:15:08.565 HD Request # 72 | Intraday data download complete for TRIN-SP. Unique request ID: 72 | 2019-12-13 02:15:08.565 Removed historical data download ID 72 | 2019-12-13 02:15:08.565 Real-time Intraday chart data file updates started for TRIN-SP | 2019-12-13 02:15:08.565 Intraday chart data file opened for TRIN-SP | 2019-12-13 02:15:08.565 Triggering next historical data download in queue. | 2019-12-13 02:15:08.566 HD Request # 73 | Downloading Intraday chart data for TVOL-NYSE to the file TVOL-NYSE.scid. Service: statscalc | 2019-12-13 02:15:08.566 HD Request # 73 | Download start date-time: 2019-12-12 16:30:00.000 | 2019-12-13 02:15:08.566 HD Request # 73 | Using server: ds4.sierracharts.com port 10150 | 2019-12-13 02:15:08.566 Socket (3) | Creating socket. | 2019-12-13 02:15:08.566 Socket (3) | Connecting to IP: 192.81.56.146. | 2019-12-13 02:15:08.566 ESZ19 [C][M] 1 Min #38 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:08.569 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:15:08.623 Socket (2) | Closed. | 2019-12-13 02:15:08.624 HD Request # 73 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:08.846 HD Request # 73 | Sending historical data logon request message. | 2019-12-13 02:15:08.846 HD Request # 73 | Requesting Intraday data. Start date-time: 2019-12-12 16:30:00. Record interval: 0. Symbol: TVOL-NYSE | 2019-12-13 02:15:08.983 HD Request # 73 | Decompressing data. | 2019-12-13 02:15:09.120 HD Request # 73 | Receiving Intraday data for TVOL-NYSE starting at 2019-12-12 16:30:00 | 2019-12-13 02:15:09.120 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:09.120 Socket (3) | Socket gracefully closed by remote side. | 2019-12-13 02:15:09.257 Socket (3) | Closed. | 2019-12-13 02:15:09.257 Chart #38 has tagged chart #23 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:09.517 Chart #38 has tagged chart #26 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:09.517 Chart #38 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:09.517 Chart #38 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:09.517 Chart #38 has tagged chart #29 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:09.517 Chart #38 has tagged chart #39 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:09.517 Historical data download thread signaled to stop. | 2019-12-13 02:15:09.544 HD Request # 73 | Received 1 record from 2019-12-12 16:30:00.000 to 2019-12-12 16:30:00.000 (0.0 seconds) and wrote 0 records for TVOL-NYSE | 2019-12-13 02:15:09.544 HD Request # 73 | Completion time: 1s | 2019-12-13 02:15:09.544 HD Request # 73 | Intraday data download complete for TVOL-NYSE. Unique request ID: 73 | 2019-12-13 02:15:09.544 Removed historical data download ID 73 | 2019-12-13 02:15:09.544 Real-time Intraday chart data file updates started for TVOL-NYSE | 2019-12-13 02:15:09.544 Intraday chart data file opened for TVOL-NYSE | 2019-12-13 02:15:09.544 Triggering next historical data download in queue. | 2019-12-13 02:15:09.544 HD Request # 74 | Downloading Intraday chart data for TICK-SP to the file TICK-SP.scid. Service: statscalc | 2019-12-13 02:15:09.545 HD Request # 74 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:15:09.545 HD Request # 74 | Using server: ds3.sierracharts.com port 10149 | 2019-12-13 02:15:09.545 Socket (2) | Creating socket. | 2019-12-13 02:15:09.545 Socket (2) | Connecting to IP: 65.182.172.42. | 2019-12-13 02:15:09.545 ESZ19 [C][M] 10 Sec #39 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:09.551 HD Request # 74 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:09.791 HD Request # 74 | Sending historical data logon request message. | 2019-12-13 02:15:09.791 HD Request # 74 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: TICK-SP | 2019-12-13 02:15:09.909 HD Request # 74 | Decompressing data. | 2019-12-13 02:15:10.027 HD Request # 74 | Receiving Intraday data for TICK-SP starting at 2019-12-12 20:00:03 | 2019-12-13 02:15:10.028 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:10.028 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:15:10.146 Socket (2) | Closed. | 2019-12-13 02:15:10.146 Historical data download thread signaled to stop. | 2019-12-13 02:15:10.197 HD Request # 74 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for TICK-SP | 2019-12-13 02:15:10.197 HD Request # 74 | Completion time: 1s | 2019-12-13 02:15:10.197 HD Request # 74 | Intraday data download complete for TICK-SP. Unique request ID: 74 | 2019-12-13 02:15:10.197 Removed historical data download ID 74 | 2019-12-13 02:15:10.197 Real-time Intraday chart data file updates started for TICK-SP | 2019-12-13 02:15:10.197 Intraday chart data file opened for TICK-SP | 2019-12-13 02:15:10.197 Triggering next historical data download in queue. | 2019-12-13 02:15:10.197 HD Request # 75 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2019-12-13 02:15:10.197 HD Request # 75 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:15:10.197 HD Request # 75 | Using server: ds4.sierracharts.com port 10150 | 2019-12-13 02:15:10.197 Socket (2) | Creating socket. | 2019-12-13 02:15:10.197 Socket (2) | Connecting to IP: 192.81.56.146. | 2019-12-13 02:15:10.198 HD Request # 75 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:10.463 HD Request # 75 | Sending historical data logon request message. | 2019-12-13 02:15:10.463 HD Request # 75 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: NISS-SP | 2019-12-13 02:15:10.592 HD Request # 75 | Decompressing data. | 2019-12-13 02:15:10.721 HD Request # 75 | Receiving Intraday data for NISS-SP starting at 2019-12-12 20:00:03 | 2019-12-13 02:15:10.721 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:10.721 Historical data download thread signaled to stop. | 2019-12-13 02:15:10.745 HD Request # 75 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for NISS-SP | 2019-12-13 02:15:10.745 HD Request # 75 | Completion time: 0s | 2019-12-13 02:15:10.745 HD Request # 75 | Intraday data download complete for NISS-SP. Unique request ID: 75 | 2019-12-13 02:15:10.745 Removed historical data download ID 75 | 2019-12-13 02:15:10.745 Real-time Intraday chart data file updates started for NISS-SP | 2019-12-13 02:15:10.745 Intraday chart data file opened for NISS-SP | 2019-12-13 02:15:10.745 Triggering next historical data download in queue. | 2019-12-13 02:15:10.745 HD Request # 76 | Downloading Intraday chart data for ADV-NYSE to the file ADV-NYSE.scid. Service: statscalc | 2019-12-13 02:15:10.745 HD Request # 76 | Download start date-time: 2019-12-12 20:00:03.000 | 2019-12-13 02:15:10.746 HD Request # 76 | Using server: ds3.sierracharts.com port 10149 | 2019-12-13 02:15:10.746 Socket (3) | Creating socket. | 2019-12-13 02:15:10.746 Socket (3) | Connecting to IP: 65.182.172.42. | 2019-12-13 02:15:10.746 Socket (2) | Socket gracefully closed by remote side. | 2019-12-13 02:15:10.851 Socket (2) | Closed. | 2019-12-13 02:15:10.851 HD Request # 76 | Setting DTC encoding to Binary VLS | 2019-12-13 02:15:10.996 HD Request # 76 | Sending historical data logon request message. | 2019-12-13 02:15:10.996 HD Request # 76 | Requesting Intraday data. Start date-time: 2019-12-12 20:00:03. Record interval: 0. Symbol: ADV-NYSE | 2019-12-13 02:15:11.114 HD Request # 76 | Decompressing data. | 2019-12-13 02:15:11.234 HD Request # 76 | Receiving Intraday data for ADV-NYSE starting at 2019-12-12 20:00:03 | 2019-12-13 02:15:11.234 Socket (3) | Shutdown started. Waiting for graceful close. | 2019-12-13 02:15:11.234 Historical data download thread signaled to stop. | 2019-12-13 02:15:11.243 HD Request # 76 | Received 1 record from 2019-12-12 20:00:03.000 to 2019-12-12 20:00:03.000 (0.0 seconds) and wrote 0 records for ADV-NYSE | 2019-12-13 02:15:11.243 HD Request # 76 | Completion time: 0s | 2019-12-13 02:15:11.244 HD Request # 76 | Intraday data download complete for ADV-NYSE. Unique request ID: 76 | 2019-12-13 02:15:11.244 Removed historical data download ID 76 | 2019-12-13 02:15:11.244 Real-time Intraday chart data file updates started for ADV-NYSE | 2019-12-13 02:15:11.244 Intraday chart data file opened for ADV-NYSE | 2019-12-13 02:15:11.244 Triggering next historical data download in queue. | 2019-12-13 02:15:11.244 Chart #49 has tagged chart #18 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.250 Chart #13 has tagged chart #20 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.251 Chart #13 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.251 Chart #13 has tagged chart #28 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.251 Chart #13 has tagged chart #29 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.251 Chart #24 has tagged chart #9 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.281 Chart #14 has tagged chart #18 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.282 Chart #14 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.282 ESZ19 [C][M] 1 Day #9 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.283 Chart #9 has tagged chart #20 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.284 Chart #9 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.284 Chart #9 has tagged chart #29 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.284 ESZ19 [C][M] 5 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.313 Socket (3) | Socket gracefully closed by remote side. | 2019-12-13 02:15:11.354 Socket (3) | Closed. | 2019-12-13 02:15:11.354 Chart #12 has tagged chart #18 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.362 ESZ19 [C][M] 10 Min #29 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.364 Chart #25 has tagged chart #27 for full recalculation. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.409 ESZ19 [CB][M] 5 Min #18 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.411 ESZ19 [CB][M] Renko 5t #23 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.448 ESZ19 [CB][M] 0.8 Range #26 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.499 ESZ19 [C][M] 30 Min #20 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.556 ESZ19 [C][M] 611 Trades #28 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.573 ESZ19 [C][M] 5 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: YONCAR-Sierra-ES.cht | 2019-12-13 02:15:11.739 |
[2019-12-13 07:19:49] |
User912279 - Posts: 102 |
This morning it doesn't work again (I tried 5 times restarting the connection already). Please answer my question above. Best Regards, |
[2019-12-13 12:51:39] |
Update Sierra Chart to the current version. The problem is you are running an older version the data feed does not support. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-13 15:25:36] |
I have updated my SierraCharts. Last update was just last month. It seems I could restart my data connection many times without a disruption (in order to achieve resetting of the pulling/stacking column). Can you tell when you will have included resetting this into the menu? |
[2019-12-13 20:00:13] |
Actually the resetting of market depth pulling and stacking is already in Sierra Chart. You can access it by right clicking on the Price scale but the menu option may be disabled and that will be solved in the next release. We did not realize this functionality was already in there when we responded previously about this.
[2019-12-13 21:23:26] |
Thank you. In fact we discussed this last November and you were working on it back then, so I guess during this year you definitely finished it. Will you enable it in the next version? Thank you. |
