Date/Time: Sat, 18 May 2024 18:02:03 +0000
Daily OHLC recalculation time
View Count: 575
[2019-11-01 05:59:20] |
User234172 - Posts: 44 |
Is there anyway to specify or manipulate the reset time for this study? Daily OHLC It works well when the session is underway, showing correctly yesterday's HL values. However, it doesn't accommodate pre-open visual chart analysis, at which stage it still shows HL values for yesterday-1. Ideally, I would want to set the time at which it is re-calculated independent of session times. A parameter such as "Recalc at Session start - n minutes" would be ideal. Assume open of a new daily bar and the start of new session and is 9am. I need to see these lines drawn for yesterday's bar before today's bar opens to aid pre-open analysis at 8am for example. Essentially differentiate between the definition of "Daily" from a session bar perspective, and "Daily" from a trader's workflow perspective. Date Time Of Last Edit: 2019-11-01 06:00:40
[2019-11-01 13:15:02] |
If the current study does not meet your needs, you will need to modify it: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
