Date/Time: Sat, 18 May 2024 15:56:19 +0000
Setting up Footprint Chart
View Count: 2246
[2019-11-01 02:20:09] |
User688882 - Posts: 1 |
Hi I was wondering how can i set up this type of number chart with the candle outline and the colored numbers. Thank you |
footprint chart.png / V - Attached On 2019-11-01 02:18:22 UTC - Size: 347.25 KB - 548 views |
[2019-11-01 14:49:02] |
This is a Numbers Bars study. There are a lot of ways to configure the Numbers Bars study to show various things. We recommend starting with this example Chartbook that has a Numbers Bar study that will give you some ideas to start with. Then just work through the various options to see how they affect things until you find the combination you are looking for. Here is the link to the chartbook: https://www.sierrachart.com/AdditionalFiles/NumbersBarsExampleChartbook.cht Here is the information on how to use the chartbook, in this case start at Step 3: Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support And here is the link to the documentation for the Numbers Bars study: Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
