Date/Time: Sat, 04 May 2024 22:25:52 +0000
REAL TIME DATA
View Count: 824
[2019-10-31 19:46:22] |
User583682 - Posts: 22 |
I just setup an account with Stage 5 Trading using GainCapital/OEC data trying to connect my SC charts to the Data feed having problems
[2019-10-31 21:19:45] |
Make sure you have gone through all of the steps in the following Setup Instructions: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SetupInstructions If you have done this and are still having problems, then follow these instructions to get us your Message Log: Clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-31 22:06:56] |
Its still not working I paid for all this data and Im still not connected Im on GAIN capital/OEC but it says (NOt Enabled on Package) what does that mean and I have package 3 which is the top package and I setup for denali and I still cant get connected
[2019-11-01 14:01:51] |
John - SC Support - Posts: 31362 |
Follow the instructions at the following link to force a login and make sure that your software is properly authorized. It sounds like it is still keeping the authorizations from before your move to Stage 5: Sierra Chart - Software Login Instructions: Forced Login For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
