Date/Time: Sat, 27 Apr 2024 20:25:51 +0000
Missing Chart Graphics text setting
View Count: 649
[2019-10-31 16:38:10] |
BenjFlame - Posts: 305 |
Hi, there is an option to set: "Trade Dom Last Traded Bid/Ask Volume Background" but unless i'm mistaking, there is no option to set "Trade Dom Last Traded Bid/Ask Volume TEXT" Which prevents good combination of colors. |
[2019-10-31 18:33:00] |
The text colors are just above those color settings.
[2019-10-31 19:44:46] |
Not exactly. "trade DOM recent Bid/ask volume" controls the text of the entire column, not specifically last traded price which is the only level with a bg color from the setting just below. Please see image text circled in blue. It is this text, when it is last trade, that needs controlled. Currently you can see that red on red is not good, and there is no way to change the text to make it stand out (I would have put it white for example). |
[2019-11-03 23:30:50] |
We will add color settings for this.
[2019-11-14 16:30:56] |
Thanks for adding this, but it doesn't work as you can see on image. Circled text should be selected color: white in this case. |
text color.PNG / V - Attached On 2019-11-14 16:30:51 UTC - Size: 48.87 KB - 230 views |
[2019-11-15 05:30:59] |
It has not been implemented. This is not easy. Allow about another 2 to 3 weeks.
[2020-02-18 17:52:35] |
We apologize for the long delay with this, we will definitely get this done, this week.
[2020-02-21 08:33:58] |
Sierra_Chart Engineering - Posts: 14110 |
This will be in version 2055.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-21 08:34:31
