Date/Time: Sat, 18 May 2024 11:28:16 +0000
Market data from source SC instance, but trades routed through different broker in dest.
View Count: 542
[2019-10-30 02:22:31] |
joshtrader - Posts: 442 |
I am using brokerage account A running on source instance SC1. I am using brokerage account B running on destination instance SC2. In SC2, I would like to use market data from brokerage account A, but route orders through brokerage account B. I thought it was possible from this page, but perhaps I've misunderstood. I have followed the directions exactly but am having some issues: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Can you confirm that the above is even possible? |
[2019-10-30 07:12:12] |
Yes it is possible but we do not provide technical help for this. So in your case you will have to consider it unsupported.
[2019-10-30 13:30:53] |
User90125 - Posts: 715 |
@joshtrader: Read the linked post below and you'll see that it can be done. Notice: Transact Websocket Connectivity Issue |
