Date/Time: Sat, 18 May 2024 06:48:15 +0000
DOM rows/cell height: getting a clean DOM with larger fonts
View Count: 830
[2019-10-29 15:28:52] |
BenjFlame - Posts: 305 |
Hello, just subscribed to SC and data... I find the software great and have never seen something with so much options. I will use the DOM a lot and wanted to make fonts higher. So I set the price and bid/ask colum font size both to 16 instead of 9. This caused unwated result and I wish to know how to resolve them. First there are tick increments levels that have disappeared. My goal was to increase font size, not to reduce vertical level of thicks. I should see all 0.25 vertical increments but the more I increase font size, the more level disappear. How to preserve all tick levels, while increasing font size? The attached image shows that price increments by 0.50 instead of 0.25 after I increased font size. Date Time Of Last Edit: 2019-10-29 15:30:07
[2019-10-29 17:27:27] |
I found solution: hold CTRL, hold mouse pointer clicked and move mouse up / down.... it will increase dom row height. What an amazing software. |
[2019-10-30 12:09:34] |
Refer to the documentation here about this: The Chart DOM Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
