Date/Time: Mon, 20 May 2024 23:34:29 +0000
Bug Report: Trade Locked Controlbar button always displays
View Count: 639
[2019-10-16 13:29:57] |
ycomp - Posts: 277 |
Trade Locked Controlbar button Tooltip always displays "Trade Locked" regardless of status (enabled or disabled). 1991 |
[2019-10-16 13:41:31] |
That is not considered a bug. This is the name of the button. And it can be enabled or disabled. There is not going to be any changes with this.
[2019-10-16 13:43:55] |
ok, I was confused because "Trading Locked" sounded like a status, compared to something like, say, "Lock Trading"
[2019-10-16 14:50:44] |
It is the same name that you see on the Trade menu. And that command can have a check mark by it indicating it is enabled. So this is why it is labeled the way it is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-16 14:50:57
[2019-10-16 20:20:19] |
ok, I understand now - tooltip text is auto-generated from the menu items. btw. there is another "bug" ... in duplicate all charts to chartbook... if you choose it and no chart is in focus, it does nothing - even though the menu item is enabled. If you first select a chart then it will display the selection dialog to choose a chartbook. |
