Date/Time: Tue, 21 May 2024 19:13:00 +0000
Re-installed: Different Layout
View Count: 642
[2019-10-16 01:37:12] |
User526399 - Posts: 2 |
Evening Charts, I recently formatted my computer to increase performance but did not transfer over the chart files onto the external so I re-installed and re-set up my charts. This layout, however, looks less "modern"? Perhaps I have installed a different version. The previous Greencharts says "Charts 1842" on top while this says "Charts 1975". I would like to revert back to how it was. http://www.sierrachart.com/image.php?Image=157118964440.png Thank you very much for your assistance, ~Thomas |
[2019-10-16 18:32:13] |
This sounds like the fonts and/or colors are just different from what you had before. Refer to the following for how to change these: Graphics Settings: Graphics Settings Controls Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-16 19:13:20] |
Thank you for the reply, I believe the whole layout looks different though. I tried reinstalling Version 1842 but it looks the same. I have a screenshot of my previous charts but was not able to upload it through the system here. |
