Date/Time: Wed, 22 May 2024 00:10:24 +0000
TD Ameritrade
View Count: 767
[2019-10-15 13:30:26] |
Ken Burks - Posts: 7 |
I want to link my account to TDA. To get futures, I understand I will need another feed. what are my options and does it integrate with TDA. I don't plan to execute trades. Thank you
[2019-10-15 17:11:00] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. TD Ameritrade in this case would be just used to verify you have a funded trading account for CME rules. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-15 17:11:22
[2019-10-17 14:03:52] |
I really only need futures data. I will trade thru TOS but want to keep my futures charts active. ES YM NQ RTY. Looking for cheapest way. Sierra- $36 and Data ?? Thanks so much |
[2019-10-17 18:25:05] |
Since you only want data from the CME Group, you can use the Denali Exchange Data Feed. The cost for the data feed itself is $25 USD per month and then there is the additional cost for the exchanges. In your case, since you are not a professional trader, it just depends on whether you want Market Depth data or not. If you want Market Depth, the cost is $15.75 USD per month, without Market Depth it is $3.25 USD per month. Refer to the following for more information, including Setup Instructions for the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
