Date/Time: Sat, 18 May 2024 19:50:38 +0000
User Email Question
View Count: 535
[2019-10-07 16:34:09] |
Sierra Chart - Max - Posts: 5618 |
I'm investigating a new platform, and I have some questions: 1) do you support continuous futures contracts, i.e., so I don't have to roll them manually? (I use Interactive Brokers). 2) Do you support futures spreads, meaning can I pull those up on a chart? 3) Does your platform support the ability to write my own indicators? 4) Does your platform support multiple brokers? i.e., so I could trade futures from say Amp and stocks from Interactive Brokers? 5) Do you have a scanner window, so I can scan multiple stocks/futures at once for specific criteria and get an alert when triggered on the scan? Thanks. Sierra Chart Support |
[2019-10-07 16:52:32] |
1. Yes. 2. Yes. 3. Yes. 4. Yes. 5. Yes. But basically you need to have charts open for each symbol and alert condition that you want to monitor at the same time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-07 16:52:48
