Date/Time: Sat, 18 May 2024 22:45:26 +0000
Chartbooks and study collections
View Count: 1120
[2019-10-07 16:07:50] |
User105769 - Posts: 10 |
Hi, I apologize if I write with the automatic translator; I had a problem with my pc so I installed sierra on another pc. The problem is that I no longer find all the saved chartbooks and various study collections I had. Is there a chance to get them back in the new PC? The one who broke does not turn on anymore. Thanks for your attention
[2019-10-07 16:10:06] |
Sierra Chart - Max - Posts: 5618 |
Chartbooks and study collections are saved on the computer locally. If you cannot access the files on your old computer, and if you did not have a backup copy of the files, then you would not be able to access them on your new computer. Also refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support Date Time Of Last Edit: 2019-10-07 17:03:23
