Date/Time: Sun, 19 May 2024 05:43:08 +0000
global setting/chart DOM setting
View Count: 581
[2019-10-07 00:10:53] |
Meimei - Posts: 1 |
My version is 1991. There is no volume bars in bid/ask for DOM in Global settings/chart DOM settings. But seems it exists in some versions. It's intentionally removed from this version? thanks
[2019-10-07 06:06:49] |
There is a new setting for this. It is documented here: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
