Date/Time: Sun, 19 May 2024 00:36:56 +0000
version 1867 not connecting
View Count: 565
[2019-10-06 16:17:44] |
OrderFlow - Posts: 26 |
I thought older 32 bit versions would still be available to use. When I try starting 32 bit version 1867 it will not connect and I get a message that I need to update?? |
[2019-10-06 16:34:10] |
Older versions are no longer allowed to use CQG. We have been providing an update notice for about the last two months. Update following the instructions here: Software Download: Fast Update Although the update should happen automatically. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-10-06 23:17:13] |
OK so with a different data feed, Rithmic for example, the older versions will work?
[2019-10-07 06:11:53] |
Yes but refer to the following regarding Rithmic: https://www.sierrachart.com/index.php?page=doc/Rithmic.php#TechnicalSupportPolicy Do not underestimate what we say there. We do not think it is a good choice to move to Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-08 02:30:04
