Date/Time: Sun, 02 Feb 2025 19:55:29 +0000
Commission Issue After Upgraded to 1991
View Count: 981
[2019-10-03 21:19:28]
Tony - Posts: 549
After I upgraded from 1953 to 1991, Sim stopped deducting
commissions from P/L (worked before upgrade). Then I noticed
"Use Commission" in Trade Activity Log was unchecked after
the upgrade, so, I checked it back, didn't help. I didn't
notice anything else had been changed, nothing has been
changed in Symbol Settings under Global Settings. Not sure
what I missed?
I had "Sierra3.cfg" backed up from my previous version, copied
it to c:\SierraChart\, didn't work either.
Thanks.
Date Time Of Last Edit: 2019-10-03 21:25:48
[2019-10-03 21:41:51]
Enable Global Settings >> Symbol Settings >> Use Custom Symbol Settings Values.
And then go to the Trade Activity Log and press the Apply button.
[2019-10-04 04:22:23]
Tony - Posts: 549
Thanks for your reply, I tried (also set the correct
commissions for the product I trade), it didn't work.
The old version of SC on my other computer doesn't
have "Use Custom Symbol Settings Value" enabled, just
have the "Use Global Round Turn Commission" enabled
and it works.
[2019-10-04 07:19:08]
samual sprat - Posts: 343
i have same issue and have custom symbol settings checked too
[2019-10-04 08:06:19]
If you are still having an issue with the commission applying, then make sure you follow all of the instructions here:
Trade Activity Log: Use Commission (Use Commission)
Date Time Of Last Edit: 2019-10-04 15:06:39
[2019-10-04 18:46:44]
Tony - Posts: 549
I followed the instruction, no luck. It doesn't
really bother me, I will leave it as-is.
It's probably safe to say that version 1953 behaved
differently with version 1991, with 1953, I didn't
have "Use Custom Symbol Settings" nor "Use Commission"
(in Trade Activity Log) enabled/checked, I just
enabled "Use Global Round Turn Commission", and Sim
deducted commission from P/L.
Thanks all the same.
[2019-10-04 18:58:44]
What symbol pattern did you set the round turn commission on in the Symbol Settings? And what is the symbol in the Trade Activity Log which you are expecting to see the commission applied to?
We also see you are using a sub instance.
Do you want to see the commission applied directly within the chart itself?
Date Time Of Last Edit: 2019-10-04 18:59:22
[2019-10-04 20:02:05]
Tony - Posts: 549
I am actually back to 1953 now. Everything works as I expect it to be.
I would like to see commissions applied in Trade Window
and "Trading: Profit/Loss Text" study on chart (Sim).
I am trading ES, but I didn't set anything for ES-######-GLOBEX,
(in Symbol Settings window)
the "Round Turn Commission" for ES-######-GLOBEX is still 0,
nor did I check "Use Custom Symbol Settings".
What I did is checking "Use Global Round Turn Commission" under
"Other Settings". I put number 4.1 in the box follows, which is
the round turn commission I pay to my broker for 1 ES contract.
The symbol in the Trade Activity Log right now is ES-201912-GLOBEX.
I do run 1 sub instance quite often, Sims in both instances deduct
commissions properly, and I didn't enable "Use Commission" in Trade
Activity Log in both instances.
Thanks,
Date Time Of Last Edit: 2019-10-07 00:34:49
[2019-10-04 21:08:37]
There definitively is no issue. There could not be. The commission functionality does work properly.
The setting you are looking for is this one:
Chart Settings: Use Symbol Commission Setting in Trade List and Statistics Calculations (Chart >> Chart Settings >> Trading menu)
[2019-10-04 21:55:16]
Tony - Posts: 549
Bingo! When "Use Symbol Commission Setting in Trade List..." is checked
(Chart Settings -> Advanced Settings 3), commissions are properly deducted
from P/L. Sorry for confusing you guys, I should've looked it harder.
Thanks very much!
