Date/Time: Sun, 19 May 2024 06:51:53 +0000
Teething problems
View Count: 949
[2019-10-02 23:47:42] |
Https://tradingbalance.co.uk - Posts: 44 |
Hello, having issues with my setup display. Is it possible to display the Market net position and net %change for a product in the top left or right of a trading DOM? Also, I am having real issues with IB and market depth on the DOM, I have upgraded my data allowance to include additional display lines but many DOMS does not display the depth. I have made sure the tickers are exact. If you can also suggest the best setup for me I would appreciate it. I am planning on having both the IB account and GHF Futures account set up. Really struggling to make the IB side work. Can you please confirm the best set up? I will be trading STOCKS and FX through IB and the majority of FUtures through GHF. Would it be kindly possible to extend my trial until I have everything set up as I am still a little lost? Kind regards Yiannis |
[2019-10-03 18:04:30] |
You can use the Current Quote Window for this: Window and CW Menus: Current Quote Window (Window) We will add the percentage change, to that window for the daily price change. Update: this has been developed and released in version 1997. We cannot help with any market data issues with Interactive Brokers, but you can use this data feed first futures: Real-Time Exchange Data Feeds Available From Sierra Chart Real-time data for US stocks is also available from this data feed but it does not provide level 2 market depth data. We cannot extend the trial . We do have to cover our support costs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-10 02:30:38
[2019-10-03 18:11:30] |
I have just subscribed. To remedy this issue regarding ib data I will need to subscribed to data twice? On IB ab be SC? I have tried to subcribe to Denali feed but there is an issue with my data subscription forms and I can not refill the forms. My username had been used in the details where name should be. Please help. I need this set up as soon as possible. |
[2019-10-04 13:41:26] |
Window and CW Menus: Current Quote Window (Window) I would like to be able to see the net change in the Dom itself without having to press buttons and fiddle. You have no idea visually where the market is relative to the previous close unless you are looking at another chart or have a good memory:) Or you can have a quote board. TT CQG STS all display this. Many thanks |
[2019-10-05 16:25:50] |
You have successfully activated the Sierra Chart Exchange Data Feed and the CME Group and EUREX exchanges. So you are fine in that regard. If you are not receiving this real-time data feed, when connected to Interactive Brokers within Sierra Chart, let us know.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-05 16:26:16
[2019-10-06 07:35:09] |
archymede - Posts: 19 |
Many thanks This is really EASY to do using the spreadsheet study and text displays studies on the dom, there could be another way but here's how I do it : 1. add a spreadsheet to your dom 2. find or calculate the values you need and put them in the right columns (K, L and so on) 3. add the text display study and configure the settings to your need Attached is an example of what can be done (blue and red prices are the high/low of the day, on the bottom you can see the daily change in ticks, the daily range and the volume) |
example.PNG / V - Attached On 2019-10-06 07:34:38 UTC - Size: 15.07 KB - 304 views |
[2019-10-06 08:20:03] |
That is perfect thank you so much Archymede. Enjoy the rest of the weekend. |
