Date/Time: Fri, 11 Sep 2026 23:45:46 +0000
[Programming Help] - Order modification after some time
View Count: 765
| [2019-09-27 15:33:28] |
| User634719 - Posts: 4 |
Hi, My goal is to modify placed order after N minutes. I've tested on AAPL symbol. I use this approach: SCDateTime TimeToCheckFor; int CurrentDate = sc.BaseDateTimeIn[sc.Index].GetDate(); int CurrentTime = sc.BaseDateTimeIn[sc.Index].GetTime(); TimeToCheckFor.SetDate(CurrentDate); TimeToCheckFor.SetTime(CurrentTime); // TimeToCheckFor is then saved in persistent storage and then at some point I check: if (sc.IsDateTimeContainedInBarIndex(TimeToCheckFor, sc.Index)) { //perform the action here } And the condition is TRUE on the first check, because if I output seconds (GetTimeInSeconds()), for example: - CurentDateTime is 64800; maybe it's time of the bar open; I guess bar "duration" is 2 hours; - if I add 120 seconds (2 min) it will be 64920; - current time at the moment when condition is checked 71250. If I use sc.ArraySize - 1 instead of sc.Index it won't work as well. I can use GetCurrentDateTime() but I guess it won't work if I apply my study to the replay. And my question is how can I do any action (e.g. modify order) after some time after I've placed the order (live stream and replay)? |
