Date/Time: Sat, 18 May 2024 14:44:05 +0000
URGENT>>ISSUE WITH BRACKET ORDERS
View Count: 701
[2019-09-24 18:01:36] |
User226793 - Posts: 160 |
Hi there, the bracket orders have not been triggered based on the setup and random number of contracts are generated. Can you please call my cell *** to resolve. this is urgent
Date Time Of Last Edit: 2019-09-24 18:27:26
[2019-09-24 18:26:20] |
If you have an urgent trading issue or action to be taken which you cannot resolve or execute through Sierra Chart, due to a connectivity issue, or other reason, then you need to immediately contact your broker to take the appropriate action. For details, refer to: Overview of Trading: Procedure to Handle Unexpected Trading Issue Our first recommendation is to cancel any outstanding orders that you have. Contact your broker if you cannot do that through Sierra Chart. And take the appropriate action on any existing positions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-24 18:28:09
[2019-09-24 18:27:15] |
Refer to our above answer. We also recommend looking at using this service instead of CQG: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-24 18:46:39
[2019-09-24 18:31:09] |
I have reached out to the broker as well.. they mentioned to me it's a sierra issue
[2019-09-24 18:49:15] |
We can certainly help you with configuration of Attached Orders, but any urgent issue first needs to be worked out with your broker if you are having any trouble with order entry in Sierra Chart or managing an existing position. This is the first step to get to a stable position. And then we can schedule a time to help you with this. And there is an additional cost. Refer to: Support and Contact - Support Options: Telephone And Interactive Remote Assistance Support Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-24 18:49:37
[2019-09-24 19:35:50] |
I am out of all positions
[2019-09-25 14:30:14] |
Can you guys help with this with an engineer. It puts in a wrong quantity, inspite of setting up the orders correctly..
[2019-09-25 14:46:08] |
User called . The problem is they were using the wrong Trade Window to set the settings for a Trading DOM. The settings were applying to a different chart that the Trade Window belonged to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-25 14:46:28
