Date/Time: Sat, 18 May 2024 16:54:21 +0000
want to set Formula Source Sheet Number by name
View Count: 892
[2019-09-24 03:30:25] |
beepboop - Posts: 3 |
After using Sierra Chart for a year with no issues (even installing all available updates), I'm running into this Formula Source Sheet Number issue in a Spreadsheet System for Trading after installing to a new machine. My buy/sell equations in K3 and M3 are being deleted, and a blank Sheet3 is automatically created. I have the Chart Data Output Specification Type set to By Name and the Chart Data Output Sheet Name set to tradeBot_foo. There is currently no way to point Formula Source Sheet Number to this same tradeBot_foo sheet. I would like to kindly request that one of two (seemingly simple) code updates be made: 1) the ability to assign Formula Source Sheet Number by name instead of number, as can be done with Chart Data Output Sheet Name 2) the ability to assign Formula Source Sheet Number to "the same sheet as Chart Data Output Sheet Name above" Thank you. |
[2019-09-24 21:46:13] |
We will be looking this over.
[2019-09-26 00:09:14] |
We will be adding support for the items you describe.
