Date/Time: Sun, 02 Feb 2025 15:53:16 +0000
Order disappeared
View Count: 984
[2019-09-18 06:53:12] |
User722622 - Posts: 1 |
I placed a limit order for 2 lots via the Sierra Chart DOM. Price came down and the order stayed open for a minute and then disappeared without filling. I looked in the Trade activity log and it said that the order time out (screenshot attached). My internet is reasonable speed for Australia and I haven't had trouble when I had Sierra directly through Transact. I have checked that my details and logins are correct and they are. If there is any other information / or logs you need, please ask. Please can you help me rectify this ASAP. Thanks so much.
Date Time Of Last Edit: 2019-09-18 08:50:22
Private File Private File |
[2019-09-18 11:38:28] |
In the version of Sierra Chart you are running, trading with Transact is not available at this time. This is a limitation with the Transact Websocket service. They will make that available soon. We are working with them on testing the new trading functionality so we expect this should be available next week.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-19 07:28:49
[2019-09-19 07:28:08] |
Refer to this post here in regards to this: Notice: Transact Websocket Connectivity Issue | Post: 192332 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
