Date/Time: Thu, 02 May 2024 20:55:57 +0000
Quoteboard - prices
View Count: 834
[2019-09-17 17:24:26] |
User495158 - Posts: 106 |
Hi! Is it possible to set up quoteboard to display previous prices, besides just the last price (for example last 5 prices)? Please see the attached screenshot displaying how the quoteboard looked like in the days of pit trading (red rectangle marking the relevant part of the CME quoteboard). Something similar would be useful. Thanks Date Time Of Last Edit: 2019-09-17 17:25:01
CME_quote.jpg / V - Attached On 2019-09-17 17:24:56 UTC - Size: 141.26 KB - 241 views |
[2019-09-19 23:23:11] |
What you can do is use a chart set to 1 Number of Trades Per Bar : Changing Chart Bars Period And then use this particular study to display the closing price below the chart bar: Study Subgraph Above/Below Bar as Text And then increase the bar spacing so there are no overlapping prices: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-19 23:23:35
[2019-09-21 22:32:28] |
Is it possible to do this with a spreadsheet formula? I would prefer a cleaner look of a quoteboard. Possibly something like this formula but instead of zigzag to have a last couple of prices Spreadsheet Example Formulas and Usage: Return Last Two Zig Zag Reversal Values Thanks Date Time Of Last Edit: 2019-09-21 23:22:01
[2019-09-22 19:36:59] |
You can certainly add a Spreadsheet Study to the chart and look at the chart values on the Sheet.
[2019-09-23 07:07:47] |
Thanks, but I'm actually trying to use the quoteboard only, because I need to check the quotes for a number of instruments (20+). It would be impractical for me to open 20 charts and use 20 spreadsheet studies. If I can achieve this with a quoteboard formula that would be great. |
