Date/Time: Sun, 24 Nov 2024 21:58:54 +0000
Sierra not responding
View Count: 1645
[2013-12-12 15:15:58] |
mattb - Posts: 30 |
began the day with a delete and download data due to rollover. use dtn iqfeed. opened chartbook and could not retrieve data before today . tried to adjust data now chartbook freezes and Sierra is not responding. please help thanks |
[2013-12-12 15:36:59] |
Sierra Chart - Max - Posts: 5730 |
Please post a copy of the Message Log following the steps here: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Do also refer to help topic 30 here: http://www.sierrachart.com/index.php?l=doc/helpdetails30.html Sierra Chart Support |
[2013-12-12 16:20:27] |
mattb - Posts: 30 |
Ok, reistalled Sierra to updated version. Chartbook now working, however still have original problem of no data before today. Today's intraday data looks fine. I cannot retrieve data before today's date. thanks |
[2013-12-12 16:21:06] |
mattb - Posts: 30 |
Software version: 1061 | 2013-12-12 10:15:49 Usage end date: 2014-03-19 | 2013-12-12 10:15:49 Enabled for: Sierra Chart Historical Data Service. | 2013-12-12 10:15:49 Active service: IQFeed | 2013-12-12 10:15:49 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-12-12 10:15:49 2013-12-12 10:15:49 Local computer clock time | 2013-12-12 10:15:49 2013-12-12 16:15:49 GMT time | 2013-12-12 10:15:49 2013-12-12 10:15:49 Time zone adjusted time | 2013-12-12 10:15:49 Time difference to server time: 0 seconds. | 2013-12-12 10:15:49 Program path: C:\SierraChart\ | 2013-12-12 10:15:49 Data Files path: C:\SierraChart\Data\ | 2013-12-12 10:15:49 OS Version Number: 6.1 | 2013-12-12 10:15:49 Checking for new symbol settings for dtn | 2013-12-12 10:15:49 IQ Feed: Connecting. | 2013-12-12 10:15:54 Starting DTN IQ Feed interface software. | 2013-12-12 10:15:54 IQ Feed: Connecting to Admin port 9300 | 2013-12-12 10:15:54 The network socket is connected. | 2013-12-12 10:15:55 IQ Feed: Connected to Admin port. | 2013-12-12 10:15:55 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2013-12-12 10:15:55 AdminMessage: S,STATS,,,,,1,0,0,0,,,Not Connected,5.1.0.4,415639,0,0,,0.03,0.0,, | 2013-12-12 10:15:55 AdminMessage: S,STATS,66.112.156.224,60003,500,,1,0,0,0,,,Not Connected,5.1.0.4,415639,0,0,,0.10,0.10,, | 2013-12-12 10:15:56 AdminMessage: S,STATS,66.112.156.224,60003,500,0,1,0,0,0,Dec 12 11:15AM,Dec 12 11:15AM,Connected,5.1.0.4,415639,0.08,0.04,0.08,0.19,0.09,0.19, | 2013-12-12 10:15:57 IQ Feed: Connecting to Level 1 port 5009 | 2013-12-12 10:15:57 The network socket is connected. | 2013-12-12 10:15:57 IQ Feed: Connected to Level 1 port. | 2013-12-12 10:15:57 IQ Feed: Connecting to Lookup port 9100 | 2013-12-12 10:15:57 IQ Feed: Connecting to Level 2 port (9200)... | 2013-12-12 10:15:57 The network socket is connected. | 2013-12-12 10:15:57 IQ Feed: Connected to Historical Data port. | 2013-12-12 10:15:57 IQ Feed: Fully connected. | 2013-12-12 10:15:57 The network socket is connected. | 2013-12-12 10:15:57 IQ Feed: Connected to Level 2 port. | 2013-12-12 10:15:57 IQ Feed: Received Server Connected message from Level 2 port. | 2013-12-12 10:15:58 IQ Feed: Level 2 port indicates market is opened. | 2013-12-12 10:15:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:59:00. Next Bar Date Time: 2013-09-12 08:59:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:59:00. Next Bar Date Time: 2013-09-12 08:59:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 17:00:00. Next Bar Date Time: 2013-09-12 17:00:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:48:14. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:16 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 10:16:16 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-12 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:16 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 10:16:16 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 17:00:00. Next Bar Date Time: 2013-09-12 17:00:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:59:00. Next Bar Date Time: 2013-09-12 08:59:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-13 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Unable to determine the symbols and settings necessary to load @ES#C.scid as a continuous contract. Make sure symbol settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 10:16:16 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-12 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:59:00. Next Bar Date Time: 2013-09-12 08:59:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:16 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 10:16:16 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:16 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 10:16:17 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: SPX.XO | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: @ES# | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: VIX.XO | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: IR6T.Z | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: OEX.XO | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: @YM# | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: NYA.X | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: COMPX.X | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: @NQ# | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: QCL# | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: @DX# | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: @EU# | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: @US# | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: QGC# | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: @C# | 2013-12-12 10:16:17 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart #31 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #31 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart: @ES#C 405 min #3 | Study: CustomVWAP | Initialized | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart: @ES#C 15000 vol #12 | Study: CustomVWAP | Initialized | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #20 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #20 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #20 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #20 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart: @ES#C 30 min #30 | Study: CustomVWAP | Initialized | 2013-12-12 10:16:17 Chart: @ES#C 7500 vol #36 | Study: CustomVWAP | Initialized | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart: @ES#C 7500 vol #11 | Study: CustomVWAP | Initialized | 2013-12-12 10:16:17 Chart: @ES#C 7500 vol #11 | Study: CustomVWAP | Initialized | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart: @ES#C 15000 vol #16 | Study: CustomVWAP | Initialized | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: @ES#C | 2013-12-12 10:16:17 HD Request # 2 - Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2013-12-12 10:16:17 HD Request # 2 - Last Date-Time in file: 2013-12-12 09:30:43.0 | 2013-12-12 10:16:17 HD Request # 2 - Requesting Tick data beginning at 2013-12-12 10:30:43 US Eastern Time. | 2013-12-12 10:16:17 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:17 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:17 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart #7 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #12 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 17:00:00. Next Bar Date Time: 2013-09-12 17:00:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #27 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: JINT.Z | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: TICK.Z | 2013-12-12 10:16:17 IQFeed - Starting real-time market data updates for: JI6T.Z | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:17 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:17 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:18 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:18 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:18 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:18 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:18 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:18 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:18 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 10:16:18 HD Request # 2 - Receiving historical Intraday Tick data for @ES#C | 2013-12-12 10:16:19 HD Request # 2 - Receiving Intraday data for @ES#C starting at 2013-12-12 09:30:43 | 2013-12-12 10:16:19 HD Request # 2 - Timestamp of first Intraday data file record written: 2013-12-12 09:30:43 | 2013-12-12 10:16:19 HD Request # 2 - Received 7604 records from 2013-12-12 09:30:43 to 2013-12-12 10:16:18 (45.6 minutes) and wrote 7599 records for @ES#C | 2013-12-12 10:16:20 HD Request # 2 - Intraday download COMPLETE for @ES#C | 2013-12-12 10:16:20 Real-time Intraday chart data file updates started for @ES#C | 2013-12-12 10:16:20 HD Request # 3 - Downloading Historical Daily chart data for SPX.XO. Starting date: 2013-12-10. Service: dtn | 2013-12-12 10:16:20 HD Request # 3 - Requesting 3 days of historical daily data. RequestID: 2 | 2013-12-12 10:16:20 Chart #31 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #31 has tagged chart #33 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #7 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 HD Request # 3 - Receiving Daily data for SPX.XO | 2013-12-12 10:16:20 HD Request # 3 - Receiving historical Daily data for SPX.XO starting at 2013-12-09 | 2013-12-12 10:16:20 Writing historical Daily data for SPX.XO to the file SPX.XO.dly | 2013-12-12 10:16:20 HD Request # 3 - Received 3 records from 2013-12-09 00:00:00 to 2013-12-11 00:00:00 (3.0 days) and wrote 2 records for SPX.XO | 2013-12-12 10:16:20 HD Request # 3 - Daily download COMPLETE for SPX.XO | 2013-12-12 10:16:20 HD Request # 4 - Downloading Historical Daily chart data for @ES#C. Starting date: 2013-12-10. Service: dtn | 2013-12-12 10:16:20 HD Request # 4 - Requesting 3 days of historical daily data. RequestID: 3 | 2013-12-12 10:16:20 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #20 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #20 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #20 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #16 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #32 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #5 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #10 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #27 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 HD Request # 4 - Receiving Daily data for @ES#C | 2013-12-12 10:16:20 HD Request # 4 - Receiving historical Daily data for @ES#C starting at 2013-12-09 | 2013-12-12 10:16:20 Writing historical Daily data for @ES#C to the file @ES#C.dly | 2013-12-12 10:16:20 HD Request # 4 - Received 3 records from 2013-12-09 00:00:00 to 2013-12-11 00:00:00 (3.0 days) and wrote 2 records for @ES#C | 2013-12-12 10:16:20 HD Request # 4 - Daily download COMPLETE for @ES#C | 2013-12-12 10:16:20 HD Request # 5 - Downloading Intraday chart data for JINT.Z to the file JINT.Z.scid. Service: dtn | 2013-12-12 10:16:20 HD Request # 5 - Last Date-Time in file: 2013-12-12 09:00:26.0 | 2013-12-12 10:16:20 HD Request # 5 - Requesting Tick data beginning at 2013-12-12 10:00:26 US Eastern Time. | 2013-12-12 10:16:20 Chart #32 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #33 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #14 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #16 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #7 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #12 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 HD Request # 5 - Receiving historical Intraday Tick data for JINT.Z | 2013-12-12 10:16:20 HD Request # 5 - Receiving Intraday data for JINT.Z starting at 2013-12-12 09:00:26 | 2013-12-12 10:16:20 HD Request # 5 - Timestamp of first Intraday data file record written: 2013-12-12 09:00:27 | 2013-12-12 10:16:20 HD Request # 5 - Received 4555 records from 2013-12-12 09:00:26 to 2013-12-12 10:16:20 (75.9 minutes) and wrote 4554 records for JINT.Z | 2013-12-12 10:16:20 HD Request # 5 - Intraday download COMPLETE for JINT.Z | 2013-12-12 10:16:20 Real-time Intraday chart data file updates started for JINT.Z | 2013-12-12 10:16:20 HD Request # 6 - Downloading Intraday chart data for TICK.Z to the file TICK.Z.scid. Service: dtn | 2013-12-12 10:16:20 HD Request # 6 - Last Date-Time in file: 2013-12-12 09:05:55.0 | 2013-12-12 10:16:20 HD Request # 6 - Requesting Tick data beginning at 2013-12-12 10:05:55 US Eastern Time. | 2013-12-12 10:16:20 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #27 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 10:16:20 HD Request # 6 - Receiving historical Intraday Tick data for TICK.Z | 2013-12-12 10:16:21 HD Request # 6 - Receiving Intraday data for TICK.Z starting at 2013-12-12 09:05:55 | 2013-12-12 10:16:21 HD Request # 6 - Timestamp of first Intraday data file record written: 2013-12-12 09:05:56 | 2013-12-12 10:16:21 HD Request # 6 - Received 4227 records from 2013-12-12 09:05:55 to 2013-12-12 10:16:21 (70.4 minutes) and wrote 4226 records for TICK.Z | 2013-12-12 10:16:21 HD Request # 6 - Intraday download COMPLETE for TICK.Z | 2013-12-12 10:16:21 Real-time Intraday chart data file updates started for TICK.Z | 2013-12-12 10:16:21 HD Request # 7 - Downloading Intraday chart data for JI6T.Z to the file JI6T.Z.scid. Service: dtn | 2013-12-12 10:16:21 HD Request # 7 - Last Date-Time in file: 2013-12-12 09:00:26.0 | 2013-12-12 10:16:21 HD Request # 7 - Requesting Tick data beginning at 2013-12-12 10:00:26 US Eastern Time. | 2013-12-12 10:16:21 HD Request # 7 - Receiving historical Intraday Tick data for JI6T.Z | 2013-12-12 10:16:21 HD Request # 7 - Receiving Intraday data for JI6T.Z starting at 2013-12-12 09:00:26 | 2013-12-12 10:16:21 HD Request # 7 - Timestamp of first Intraday data file record written: 2013-12-12 09:00:27 | 2013-12-12 10:16:21 HD Request # 7 - Received 4556 records from 2013-12-12 09:00:26 to 2013-12-12 10:16:21 (75.9 minutes) and wrote 4555 records for JI6T.Z | 2013-12-12 10:16:21 HD Request # 7 - Intraday download COMPLETE for JI6T.Z | 2013-12-12 10:16:21 Real-time Intraday chart data file updates started for JI6T.Z | 2013-12-12 10:16:21 |
[2013-12-12 17:49:12] |
mattb - Posts: 30 |
Software version: 1061 | 2013-12-12 11:07:04 Usage end date: 2014-03-19 | 2013-12-12 11:07:04 Enabled for: Sierra Chart Historical Data Service. | 2013-12-12 11:07:04 Active service: IQFeed | 2013-12-12 11:07:04 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-12-12 11:07:04 2013-12-12 11:07:04 Local computer clock time | 2013-12-12 11:07:04 2013-12-12 17:07:04 GMT time | 2013-12-12 11:07:04 2013-12-12 11:07:04 Time zone adjusted time | 2013-12-12 11:07:04 Time difference to server time: 1 seconds. | 2013-12-12 11:07:04 Program path: C:\SierraChart\ | 2013-12-12 11:07:04 Data Files path: C:\SierraChart\Data\ | 2013-12-12 11:07:04 OS Version Number: 6.1 | 2013-12-12 11:07:04 Checking for new symbol settings for dtn | 2013-12-12 11:07:04 IQ Feed: Connecting. | 2013-12-12 11:07:09 Starting DTN IQ Feed interface software. | 2013-12-12 11:07:09 IQ Feed: Connecting to Admin port 9300 | 2013-12-12 11:07:09 The network socket is connected. | 2013-12-12 11:07:09 IQ Feed: Connected to Admin port. | 2013-12-12 11:07:09 AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2013-12-12 11:07:09 AdminMessage: S,STATS,,,,,1,0,0,0,,,Not Connected,5.1.0.4,415639,0,0,,0.03,0.03,, | 2013-12-12 11:07:10 AdminMessage: S,STATS,,,500,,1,0,0,0,,,Not Connected,5.1.0.4,415639,0,0,,0.10,0.05,, | 2013-12-12 11:07:11 AdminMessage: S,STATS,66.112.156.115,60002,500,,1,0,0,0,,,Not Connected,5.1.0.4,415639,0,0,,0.17,0.06,, | 2013-12-12 11:07:12 AdminMessage: S,STATS,66.112.156.115,60002,500,0,1,1,0,0,Dec 12 12:07PM,Dec 12 12:07PM,Connected,5.1.0.4,415639,0.06,0.02,0.06,0.26,0.06,0.26, | 2013-12-12 11:07:13 IQ Feed: Connecting to Level 1 port 5009 | 2013-12-12 11:07:13 The network socket is connected. | 2013-12-12 11:07:13 IQ Feed: Connected to Level 1 port. | 2013-12-12 11:07:13 IQ Feed: Connecting to Lookup port 9100 | 2013-12-12 11:07:13 IQ Feed: Connecting to Level 2 port (9200)... | 2013-12-12 11:07:13 The network socket is connected. | 2013-12-12 11:07:13 IQ Feed: Connected to Historical Data port. | 2013-12-12 11:07:13 IQ Feed: Fully connected. | 2013-12-12 11:07:13 The network socket is connected. | 2013-12-12 11:07:13 IQ Feed: Connected to Level 2 port. | 2013-12-12 11:07:13 IQ Feed: Received Server Connected message from Level 2 port. | 2013-12-12 11:07:13 IQ Feed: Level 2 port indicates market is opened. | 2013-12-12 11:07:13 Unable to determine the symbols and settings necessary to load @ES#C.scid as a continuous contract. Make sure symbol settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:27 Unable to determine the symbols and settings necessary to load @ES#C.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:27 Unable to determine the symbols and settings necessary to load QCL#C.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:27 IQFeed - Starting real-time market data updates for: @ES#C | 2013-12-12 11:07:27 HD Request # 2 - Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2013-12-12 11:07:27 HD Request # 2 - Last Date-Time in file: 2013-12-12 10:30:54.0 | 2013-12-12 11:07:27 HD Request # 2 - Requesting Tick data beginning at 2013-12-12 11:30:54 US Eastern Time. | 2013-12-12 11:07:27 IQFeed - Starting real-time market data updates for: TICK.Z | 2013-12-12 11:07:27 IQFeed - Starting real-time market data updates for: QCL#C | 2013-12-12 11:07:27 Unable to determine the symbols and settings necessary to load @ES#C.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:29 Unable to determine the symbols and settings necessary to load QCL#C.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:29 HD Request # 2 - Receiving historical Intraday Tick data for @ES#C | 2013-12-12 11:07:30 HD Request # 2 - Receiving Intraday data for @ES#C starting at 2013-12-12 10:30:54 | 2013-12-12 11:07:30 HD Request # 2 - Timestamp of first Intraday data file record written: 2013-12-12 10:30:57 | 2013-12-12 11:07:30 HD Request # 2 - Received 4327 records from 2013-12-12 10:30:54 to 2013-12-12 11:07:29 (36.6 minutes) and wrote 4325 records for @ES#C | 2013-12-12 11:07:30 HD Request # 2 - Intraday download COMPLETE for @ES#C | 2013-12-12 11:07:30 Real-time Intraday chart data file updates started for @ES#C | 2013-12-12 11:07:30 HD Request # 3 - Downloading Intraday chart data for TICK.Z to the file TICK.Z.scid. Service: dtn | 2013-12-12 11:07:30 HD Request # 3 - Last Date-Time in file: 2013-12-12 10:30:55.0 | 2013-12-12 11:07:30 HD Request # 3 - Requesting Tick data beginning at 2013-12-12 11:30:55 US Eastern Time. | 2013-12-12 11:07:30 Chart #5 has tagged chart #6 for full recalculation. Chartbook: ES Daily Chartbook.cht | 2013-12-12 11:07:30 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: ES Daily Chartbook.cht | 2013-12-12 11:07:30 HD Request # 3 - Receiving historical Intraday Tick data for TICK.Z | 2013-12-12 11:07:30 HD Request # 3 - Receiving Intraday data for TICK.Z starting at 2013-12-12 10:30:55 | 2013-12-12 11:07:30 HD Request # 3 - Timestamp of first Intraday data file record written: 2013-12-12 10:30:56 | 2013-12-12 11:07:30 HD Request # 3 - Received 2196 records from 2013-12-12 10:30:55 to 2013-12-12 11:07:30 (36.6 minutes) and wrote 2195 records for TICK.Z | 2013-12-12 11:07:30 HD Request # 3 - Intraday download COMPLETE for TICK.Z | 2013-12-12 11:07:30 Real-time Intraday chart data file updates started for TICK.Z | 2013-12-12 11:07:30 Added 1 Time and Sales records to Intraday data file for TICK.Z after download. | 2013-12-12 11:07:30 HD Request # 4 - Downloading Historical Daily chart data for @ES#C. Starting date: 2013-12-10. Service: dtn | 2013-12-12 11:07:30 HD Request # 4 - Requesting 3 days of historical daily data. RequestID: 3 | 2013-12-12 11:07:30 HD Request # 4 - Receiving Daily data for @ES#C | 2013-12-12 11:07:31 HD Request # 4 - Receiving historical Daily data for @ES#C starting at 2013-12-09 | 2013-12-12 11:07:31 Writing historical Daily data for @ES#C to the file @ES#C.dly | 2013-12-12 11:07:31 HD Request # 4 - Received 3 records from 2013-12-09 00:00:00 to 2013-12-11 00:00:00 (3.0 days) and wrote 2 records for @ES#C | 2013-12-12 11:07:31 HD Request # 4 - Daily download COMPLETE for @ES#C | 2013-12-12 11:07:31 Unable to determine the symbols and settings necessary to load @ES#C.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:31 HD Request # 5 - Downloading Historical Daily chart data for QCL#C. Starting date: 2013-12-10. Service: dtn | 2013-12-12 11:07:31 HD Request # 5 - Requesting 3 days of historical daily data. RequestID: 4 | 2013-12-12 11:07:31 HD Request # 5 - Receiving Daily data for QCL#C | 2013-12-12 11:07:31 HD Request # 5 - Receiving historical Daily data for QCL#C starting at 2013-12-09 | 2013-12-12 11:07:31 Writing historical Daily data for QCL#C to the file QCL#C.dly | 2013-12-12 11:07:31 HD Request # 5 - Received 3 records from 2013-12-09 00:00:00 to 2013-12-11 00:00:00 (3.0 days) and wrote 2 records for QCL#C | 2013-12-12 11:07:31 HD Request # 5 - Daily download COMPLETE for QCL#C | 2013-12-12 11:07:31 Unable to determine the symbols and settings necessary to load QCL#C.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:31 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:59:00. Next Bar Date Time: 2013-09-12 08:59:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:59:00. Next Bar Date Time: 2013-09-12 08:59:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 17:00:00. Next Bar Date Time: 2013-09-12 17:00:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:48:14. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-12 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 17:00:00. Next Bar Date Time: 2013-09-12 17:00:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:59:00. Next Bar Date Time: 2013-09-12 08:59:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-13 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Unable to determine the symbols and settings necessary to load @ES#C.scid as a continuous contract. Make sure symbol settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:55 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-12 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:59:00. Next Bar Date Time: 2013-09-12 08:59:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 11:07:55 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Notice: The study 'CustomVWAP' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: SPX.XO | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: @ES# | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: VIX.XO | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: IR6T.Z | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: OEX.XO | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: @YM# | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: NYA.X | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: COMPX.X | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: @NQ# | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: QCL# | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: @DX# | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: @EU# | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: @US# | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: QGC# | 2013-12-12 11:07:55 IQFeed - Starting real-time market data updates for: @C# | 2013-12-12 11:07:55 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Chart #31 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:55 Chart #31 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:55 Chart: @ES#C 405 min #3 | Study: CustomVWAP | Initialized | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Chart: @ES#C 15000 vol #12 | Study: CustomVWAP | Initialized | 2013-12-12 11:07:55 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:55 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:55 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:55 Chart #20 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:55 Chart #20 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:55 Chart #20 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:55 Chart #20 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:55 Chart: @ES#C 30 min #30 | Study: CustomVWAP | Initialized | 2013-12-12 11:07:56 Chart: @ES#C 7500 vol #36 | Study: CustomVWAP | Initialized | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Chart: @ES#C 7500 vol #11 | Study: CustomVWAP | Initialized | 2013-12-12 11:07:56 Chart: @ES#C 7500 vol #11 | Study: CustomVWAP | Initialized | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Chart: @ES#C 15000 vol #16 | Study: CustomVWAP | Initialized | 2013-12-12 11:07:56 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:56 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:56 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 HD Request # 6 - Downloading Historical Daily chart data for SPX.XO. Starting date: 2013-12-10. Service: dtn | 2013-12-12 11:07:56 HD Request # 6 - Requesting 3 days of historical daily data. RequestID: 5 | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 HD Request # 6 - Receiving Daily data for SPX.XO | 2013-12-12 11:07:56 HD Request # 6 - Receiving historical Daily data for SPX.XO starting at 2013-12-09 | 2013-12-12 11:07:56 Writing historical Daily data for SPX.XO to the file SPX.XO.dly | 2013-12-12 11:07:56 HD Request # 6 - Received 3 records from 2013-12-09 00:00:00 to 2013-12-11 00:00:00 (3.0 days) and wrote 2 records for SPX.XO | 2013-12-12 11:07:56 HD Request # 6 - Daily download COMPLETE for SPX.XO | 2013-12-12 11:07:56 Chart #7 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Chart #12 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-11 17:00:00. Next Bar Date Time: 2013-09-12 17:00:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:07:56 Chart #27 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 IQFeed - Starting real-time market data updates for: JINT.Z | 2013-12-12 11:07:56 HD Request # 7 - Downloading Intraday chart data for JINT.Z to the file JINT.Z.scid. Service: dtn | 2013-12-12 11:07:56 HD Request # 7 - Last Date-Time in file: 2013-12-12 10:30:55.0 | 2013-12-12 11:07:56 HD Request # 7 - Requesting Tick data beginning at 2013-12-12 11:30:55 US Eastern Time. | 2013-12-12 11:07:56 IQFeed - Starting real-time market data updates for: JI6T.Z | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:07:56 HD Request # 7 - Receiving historical Intraday Tick data for JINT.Z | 2013-12-12 11:07:56 HD Request # 7 - Receiving Intraday data for JINT.Z starting at 2013-12-12 10:30:55 | 2013-12-12 11:07:56 HD Request # 7 - Timestamp of first Intraday data file record written: 2013-12-12 10:30:56 | 2013-12-12 11:07:56 HD Request # 7 - Received 2223 records from 2013-12-12 10:30:55 to 2013-12-12 11:07:57 (37.0 minutes) and wrote 2222 records for JINT.Z | 2013-12-12 11:07:56 HD Request # 7 - Intraday download COMPLETE for JINT.Z | 2013-12-12 11:07:56 Real-time Intraday chart data file updates started for JINT.Z | 2013-12-12 11:07:56 HD Request # 8 - Downloading Intraday chart data for JI6T.Z to the file JI6T.Z.scid. Service: dtn | 2013-12-12 11:07:56 HD Request # 8 - Last Date-Time in file: 2013-12-12 10:30:55.0 | 2013-12-12 11:07:56 HD Request # 8 - Requesting Tick data beginning at 2013-12-12 11:30:55 US Eastern Time. | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:56 HD Request # 8 - Receiving historical Intraday Tick data for JI6T.Z | 2013-12-12 11:07:56 HD Request # 8 - Receiving Intraday data for JI6T.Z starting at 2013-12-12 10:30:55 | 2013-12-12 11:07:56 HD Request # 8 - Timestamp of first Intraday data file record written: 2013-12-12 10:30:56 | 2013-12-12 11:07:56 HD Request # 8 - Received 2223 records from 2013-12-12 10:30:55 to 2013-12-12 11:07:57 (37.0 minutes) and wrote 2222 records for JI6T.Z | 2013-12-12 11:07:56 HD Request # 8 - Intraday download COMPLETE for JI6T.Z | 2013-12-12 11:07:57 Real-time Intraday chart data file updates started for JI6T.Z | 2013-12-12 11:07:57 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:57 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:57 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:57 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:57 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:58 Error loading custom studies DLL: C:\SierraChart\Data\CustomVWAP.dll. Windows error code 126: The specified module could not be found. | 2013-12-12 11:07:58 Remote instance connected: | 2013-12-12 11:30:13 Current selected Data/Trading service: IQFeed | 2013-12-12 11:33:27 Starting downloads for all open Historical Daily data charts. | 2013-12-12 11:34:23 HD Request # 9 - Downloading Historical Daily chart data for @ES#C. Starting date: 2013-01-01. Service: dtn | 2013-12-12 11:34:23 HD Request # 9 - Requesting 346 days of historical daily data. RequestID: 8 | 2013-12-12 11:34:23 HD Request # 9 - Receiving Daily data for @ES#C | 2013-12-12 11:34:23 HD Request # 9 - Receiving historical Daily data for @ES#C starting at 2012-07-31 | 2013-12-12 11:34:23 Writing historical Daily data for @ES#C to the file @ES#C.dly | 2013-12-12 11:34:23 HD Request # 9 - Received 346 records from 2012-07-31 00:00:00 to 2013-12-11 00:00:00 (499.0 days) and wrote 239 records for @ES#C | 2013-12-12 11:34:23 HD Request # 9 - Daily download COMPLETE for @ES#C | 2013-12-12 11:34:23 Unable to determine the symbols and settings necessary to load @ES#C.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:34:24 HD Request # 10 - Downloading Historical Daily chart data for QCL#C. Starting date: 2013-01-01. Service: dtn | 2013-12-12 11:34:24 HD Request # 10 - Requesting 346 days of historical daily data. RequestID: 9 | 2013-12-12 11:34:24 HD Request # 10 - Receiving Daily data for QCL#C | 2013-12-12 11:34:24 HD Request # 10 - Receiving historical Daily data for QCL#C starting at 2012-07-31 | 2013-12-12 11:34:24 Writing historical Daily data for QCL#C to the file QCL#C.dly | 2013-12-12 11:34:24 HD Request # 10 - Received 346 records from 2012-07-31 00:00:00 to 2013-12-11 00:00:00 (499.0 days) and wrote 239 records for QCL#C | 2013-12-12 11:34:24 HD Request # 10 - Daily download COMPLETE for QCL#C | 2013-12-12 11:34:24 Unable to determine the symbols and settings necessary to load QCL#C.dly as a continuous contract. Make sure Symbol Settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:34:24 HD Request # 11 - Downloading Historical Daily chart data for SPX.XO. Starting date: 2013-01-01. Service: dtn | 2013-12-12 11:34:24 HD Request # 11 - Requesting 346 days of historical daily data. RequestID: 10 | 2013-12-12 11:34:24 HD Request # 11 - Receiving Daily data for SPX.XO | 2013-12-12 11:34:24 HD Request # 11 - Receiving historical Daily data for SPX.XO starting at 2012-07-27 | 2013-12-12 11:34:24 Writing historical Daily data for SPX.XO to the file SPX.XO.dly | 2013-12-12 11:34:24 HD Request # 11 - Received 346 records from 2012-07-27 00:00:00 to 2013-12-11 00:00:00 (503.0 days) and wrote 239 records for SPX.XO | 2013-12-12 11:34:24 HD Request # 11 - Daily download COMPLETE for SPX.XO | 2013-12-12 11:34:24 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-13 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:35:39 Current selected Data/Trading service: IQFeed | 2013-12-12 11:35:54 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-13 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:36:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:45. Next Bar Date Time: 2013-09-12 08:59:52. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:37:36 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:37:36 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:37:36 Chart #7 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:37:36 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:37:36 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:37:36 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:37:36 Chart #27 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:37:37 Current selected Data/Trading service: IQFeed | 2013-12-12 11:39:36 Current selected Data/Trading service: IQFeed | 2013-12-12 11:39:49 Reloading all charts with filename: @ES#C.scid | 2013-12-12 11:40:45 Unable to determine the symbols and settings necessary to load @ES#C.scid as a continuous contract. Make sure symbol settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:40:46 Unable to determine the symbols and settings necessary to load @ES#C.scid as a continuous contract. Make sure symbol settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:40:47 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:40:48 HD Request # 12 - Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2013-12-12 11:40:48 Compressing file: C:\SierraChart\Data\@ES#C.temp.scid. This may take a while... | 2013-12-12 11:40:48 HD Request # 12 - Last Date-Time in file: 00:00:00.0 | 2013-12-12 11:40:48 HD Request # 12 - Requesting Minute data beginning at 2011-12-13 12:40:48 US Eastern Time. | 2013-12-12 11:40:48 HD Request # 12 - Receiving Intraday Minute data for @ES#C | 2013-12-12 11:40:50 HD Request # 12 - Receiving Intraday data for @ES#C starting at 2011-12-13 11:41:00 | 2013-12-12 11:40:50 HD Request # 12 - Timestamp of first Intraday data file record written: 2011-12-13 11:41:00 | 2013-12-12 11:40:50 HD Request # 12 - Error downloading historical Intraday data for @ES#C. The download timed out. | 2013-12-12 11:43:52 HD Request # 12 - Received 90000 records from 2011-12-13 11:41:00 to 2012-03-19 17:22:00 (97.2 days) and wrote 90000 records for @ES#C | 2013-12-12 11:43:52 HD Request # 12 - Intraday download COMPLETE for @ES#C | 2013-12-12 11:43:52 HD Request # 13 - Downloading Intraday chart data for @ES#C to the file @ES#C.scid. Service: dtn | 2013-12-12 11:43:52 HD Request # 13 - Last Date-Time in file: 00:00:00.0 | 2013-12-12 11:43:52 HD Request # 13 - Requesting Tick data beginning at 2011-12-13 12:43:52 US Eastern Time. | 2013-12-12 11:43:52 HD Request # 13 - Error downloading historical Intraday data for @ES#C. The download timed out. | 2013-12-12 11:46:52 HD Request # 13 - Received 0 records and wrote 0 records for @ES#C | 2013-12-12 11:46:52 HD Request # 13 - Copying downloaded Intraday chart data from @ES#C.temp.scid to @ES#C.scid | 2013-12-12 11:46:52 Reloading all charts with filename: @ES#C.scid | 2013-12-12 11:46:52 Unable to determine the symbols and settings necessary to load @ES#C.scid as a continuous contract. Make sure symbol settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:46:53 Unable to determine the symbols and settings necessary to load @ES#C.scid as a continuous contract. Make sure symbol settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:46:53 HD Request # 13 - Intraday download COMPLETE for @ES#C | 2013-12-12 11:46:54 Real-time Intraday chart data file updates started for @ES#C | 2013-12-12 11:46:54 Added 228 Time and Sales records to Intraday data file for @ES#C after download. | 2013-12-12 11:46:54 Chart #5 has tagged chart #6 for full recalculation. Chartbook: ES Daily Chartbook.cht | 2013-12-12 11:46:54 Chart #5 has tagged chart #6 for full recalculation. Chartbook: ES Daily Chartbook.cht | 2013-12-12 11:46:54 Chart #5 has tagged chart #6 for full recalculation. Chartbook: ES Daily Chartbook.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #16 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #32 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #5 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #16 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #32 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #5 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #16 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #32 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #5 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #10 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #15 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #18 has tagged chart #7 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #31 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #31 has tagged chart #33 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #31 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #31 has tagged chart #33 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #31 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #31 has tagged chart #33 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #7 has tagged chart #27 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #7 has tagged chart #8 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #12 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #14 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #20 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #33 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: ES Daily Chartbook.cht | 2013-12-12 11:46:54 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #12 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #12 has tagged chart #25 for full recalculation. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:54 Chart #25 is performing a full recalculation because it has been tagged. Chartbook: 1_ESWorkstation_DEC.cht | 2013-12-12 11:46:55 |
[2013-12-12 18:12:49] |
mattb - Posts: 30 |
opening chartbook freezes Sierra again.
[2013-12-12 20:15:04] |
For this, refer to help topic 7: http://www.sierrachart.com/index.php?l=doc/helpdetails7.html Today's intraday data looks fine. I cannot retrieve data before today's date. For this, do not use the Continuous Futures Contract setting in Chart Settings: Unable to determine the symbols and settings necessary to load @ES#C.scid as a continuous contract. Make sure symbol settings exist and are correct for this symbol in Global Settings >> Symbol Settings. | 2013-12-12 11:07:27
For the Chartbook freezing issue, refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails30.html#h30.16 We recommend creating a new Chartbook. You are using custom studies which can also be causing a problem. We cannot help with those. Refer to help topic 17 about those: http://www.sierrachart.com/index.php?l=doc/helpdetails17.html For this one, refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails63.html Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-12 08:30:00. Next Bar Date Time: 2013-09-13 08:30:00. Filename: C:\SierraChart\Data\@ES#C.scid | 2013-12-12 11:36:58 We tested downloading data for @ES#C from IQ Feed. The data was downloaded reliably and very fast. No trouble at all and no out of order timestamps. Sometimes based upon your Chartbook configuration, as data is being downloaded, this can increase CPU usage due to a lot of additional processing that goes on within those charts. The solution is just to open a a single chart without studies when you are managing the data and then when you have all of the data, at that time go ahead and open up your complex Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-12 20:17:07
