Date/Time: Sun, 02 Feb 2025 12:53:48 +0000
Study Subgraph Multiply Line does NOT Plot
View Count: 627
[2019-09-12 12:59:21]
User360283 - Posts: 508
V 1987 64bit
Input Study Daily OHLC Close
Multiplier 0.995
Text display of result shows correct value
Line does not plot
Help please
[2019-09-12 16:34:53]
I've also tried making the multiplier = 1 and the line still does not plot.
[2019-09-13 11:23:11]
Most likely what you are seeing is that there is only a single value for the Study Subgraph Multiply and it is being drawn into a separate region, therefore it is drawing the line at the top of the region, which can look like nothing is drawn in there.
Given what you want to do, it sounds like you just need to change the Region for the Study Subgraph Multiply to Region 1. Refer to the following:
Chart Studies: Settings and Inputs Tab >> Chart Region
