Date/Time: Sun, 05 May 2024 08:17:05 +0000
IMPORTANT: TD Ameritrade Support to End December 31, 2019
View Count: 6965
[2020-04-01 16:22:47] |
RayRay - Posts: 3 |
Is there a direct link to version 2025/2021 which still supports TD we can get and see if the TD login still works? This is while I look to for another brokerage going forward for Live data.. Thanks |
[2020-05-28 14:49:44] |
jumpinjack - Posts: 3 |
(Non Professional) Need at reasonable "realtime" data feed since TD Am is no longer available at SC. I only trade ETFs: $SPY $QQQs. Futures or FX not necessary.
[2020-05-28 21:09:59] |
You can get this real-time data for 35 USD per month with the Sierra Chart exchange data feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
