Date/Time: Sun, 19 May 2024 14:46:32 +0000
Transact Futures
View Count: 1551
[2019-09-06 05:11:29] |
User213479 - Posts: 7 |
Hello, I have updated my account information. How do I add Denali Exchange Services and get market depth. Again, I pay for Sierra chart itself through Infinity Futures. |
[2019-09-06 15:40:57] |
We have started this for you, check your email for a message with two agreements which need to be completed. Let us know when done.
[2019-09-06 21:54:39] |
Completed the agreements.
[2019-09-06 23:21:36] |
SC Support - Posts: 1801 |
We can give you a call to help you move through the rest of the process.
[2019-09-07 01:11:29] |
User593282 - Posts: 11 |
Yes, when can you call? I live in Chicago. |
[2019-09-07 01:45:13] |
I can call within the next 30 minutes, if that works for you.
[2019-09-07 02:30:39] |
Yes, please call any time now.
[2019-09-07 02:45:00] |
Could you please call me now. My apologies, I stepped away for a moment, when you called. Please, thank you!!! :-) |
[2019-09-07 02:45:06] |
Hi, We missed you with our call just now. We will try you again tomorrow afternoon.
[2019-09-07 02:46:03] |
Could you please try again right now. I am by my phone. My apologies. I would like to set it up today. I have been trying for a week now.
[2019-09-07 02:50:50] |
Could you please call now? I have my phone by my side. You can call any time during the night (it is night time here in Chicago). I would rather do this tonight. B/c this has taken quite a bit of my time to set this up. |
[2019-09-07 03:07:51] |
There is no need for us to call. We have completed the setup of the data feed on your Sierra Chart account. But now that we check, the version you are running is an older version. You must update to the current version. You cannot run version 1881. But the latest version, does not support trading with Transact because that is not yet available from them. We expect Transact to make trading available in September over their websocket connection which the newer versions use. If you do not want to update you cannot use the Denali exchange data feed and we need to cancel it for you. Follow the instructions here to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-07 03:09:09
[2019-09-07 03:26:07] |
I do want to use the Denali exchange feed, b/c I want to see 200-300 levels of market depth. Do you know when Transact will update to the new Sierra version. Also, what is the version # to which I need to update. What is the current version of the Sierra chart? |
[2019-09-07 03:33:53] |
The current version is 1986 and you just need to follow the instructions here: Software Download: Fast Update When Transact will be releasing support for trading over their new websocket connection which newer versions of Sierra Chart uses, we expect will be in the month of September 2019. Also to make sure you see the number of levels of depth that you want, adjust this setting as required: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-07 03:36:30
[2019-09-07 03:36:35] |
Prior post has been updated.
[2019-09-07 03:51:32] |
I currently have 1881 version and you have 1986, why such a huge jump in version #'s? When was 1881 version released?
[2019-09-07 03:56:28] |
Please understand we are very busy and we cannot be spending time on questions like these. You need to update. And besides you can see all of the history here anyway: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-07 03:57:00
