Date/Time: Mon, 10 Mar 2025 00:50:36 +0000
SC Data Missing Bars after Renewing
View Count: 656
[2019-09-05 16:00:43]
User260560 - Posts: 37
Hi there, I forgot to renew my sierra chart data before the end of the month, so they got cancelled and I had to renew, but after I did that, i found out that if a ticker is not on my chart before the market open and i open it during the market hour, some of the data on my 5min chart is missing. I remember the same thing happened a while ago when i renewed the data after the month end, and needed you guys to reset something in the back end to fix that problem. Please help me with that, thanks!
[2019-09-05 17:28:35]
This issue is not related to the Sierra Chart account status or when you renewed.
There is some other technical problem on your side.
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2019-09-06 17:49:27]
Thanks for your replay! It seems that the issue is fixed now. Have a great weekend!
