Date/Time: Tue, 14 May 2024 00:15:13 +0000
Hand dragging not working to go up and down on chart book
View Count: 542
[2019-09-02 16:41:36] |
User636141 - Posts: 13 |
What needs to be done? Thank you, Arjuna |
[2019-09-03 03:45:14] |
Refer to the documentation for this here: Chart Drawing Tools: Hand (Hand tool) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
