Date/Time: Fri, 10 May 2024 08:30:28 +0000
2 systems allowed
View Count: 768
[2019-09-02 12:35:52] |
User450179 - Posts: 105 |
Hi I am mixed up on how many systems I can use persoanlly for myself with Sierra Chart. My account management says i am currently using 1 of 2 systems. Does this mean that I can use 2 computers at home with 2 separate and completely independent versions of sierra chart running on them? I understand I can use the instances feature to help reduce cpu/core work load but using another computer would be great since I already have a few. Thank you in advance. Would I need to pay for data again with the CME and with Sierra if i use your realtime feed? |
[2019-09-03 01:32:53] |
This is documented here: Sierra Chart Purchase and License Information: Licensing / Number of Systems Regarding this when using the Sierra Chart Exchange Data Feed, refer to: Sierra Chart Exchange Data Feed: Connections If you are using the Denali Exchange Data Feed it supports two connections simultaneously. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
