Date/Time: Sat, 11 May 2024 09:41:52 +0000
quote board
View Count: 548
[2019-09-02 12:18:16] |
User657945 - Posts: 226 |
How is it possible to copy a quote board created in a chartobook to a another chartbook? thx
[2019-09-02 12:25:08] |
You can save the Symbol List and load it into another Quote Board. Refer to: Getting Quotes: Saving/Loading Symbol Lists and Importing Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-02 12:35:48] |
thx more easy than I thought
