Date/Time: Fri, 10 May 2024 05:04:21 +0000
Out of bounds array error at Index 399
View Count: 674
[2019-09-02 03:43:27] |
User556932 - Posts: 31 |
Hi SC Engineering Yesterday I uploaded version 1983. I am performing Auto Trade System Bar Based Back Tests on various Symbols and am often getting a message such as Chart #2|Base Graph ID:0 Out of bounds array error at Index 399|2019-09-02 13:22:59.658 and Bar Backtest: XAUUSD[M] 240M #2 Backtest processing : NumberOfTimesCalculateCalled(Culmulative) = 0 | 2019-09-02 13:22:01.764 I have also noticed that -sometimes the backtest will not complete for the number of days eg if ChartSettings>>>Use Number of days to Load is set to 365, the Trade Activity Log results may not go for the full 365 days (noting I have the correct Date Range to display) . This is also consistent with Show Order Fills cutting out after a period of time. - Symbols now have an [M] following them.... is this related? Would appreciate any assistance you may be able to provide, Regards |
[2019-09-02 12:29:47] |
You can safely ignore that out of bounds array error. That is not specific to version 1983. -sometimes the backtest will not complete for the number of days eg if ChartSettings>>>Use Number of days to Load is set to 365, the Trade Activity Log results may not go for the full 365 days (noting I have the correct Date Range to display) . This is also consistent with Show Order Fills cutting out after a period of time. You have to debug this yourself. This is not something we provide help with. Other than referring to this documentation:Refer to this section: Automated Trading Management: Troubleshooting Automated Trading System Behavior Bar Backtest: XAUUSD[M] 240M #2 Backtest processing : NumberOfTimesCalculateCalled(Culmulative) = 0 | 2019-09-02 13:22:01.764 This is fine as well.- Symbols now have an [M] following them.... is this related? This is not related and is fine. Refer to:Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-02 12:29:59
