Date/Time: Fri, 10 May 2024 05:45:08 +0000
Denali feed historical data missing
View Count: 770
[2019-09-01 17:56:35] |
User138602 - Posts: 169 |
TN?#-CBOT UB?#-CBOT ZB?#-CBOT ZN?#-CBOT ZT?#-CBOT ZF?#-CBOT (U.S. T-Bonds and Notes) These Furter Symbols are missing historical data. Can someone confirm this please? XC?# XK?# XW?# YM?# ZC?# ZL?# ZM?# ZS?# ZW?# Thx Date Time Of Last Edit: 2019-09-01 19:03:28
[2019-09-02 00:36:17] |
We need to know what specific historical data you are referring to. Are you referring to Historical Intraday data or Daily data?
[2019-09-02 00:40:56] |
Another thing you need to be aware of is because Monday is a holiday in the US, there is not going to be any daily bar for Monday. It will not exist. Although you should see a bar for Sunday but that is not going to persist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-02 00:41:18
[2019-09-02 08:36:42] |
I didnt check the following for every symbol, but it seems that only ONE weekly/monthly/quarterly and yearly bar gets calculated. Daily, as far as i can see, is fine although i dont know how much daily data is available....surely several weeks. There should be several weekly, monthly ect. bars. PS: Can you give me pls a hint why you seem to avoid this thread? Maybe you have a policy regarding this topic i should know about? Color background based on alert condition on horizontal line Date Time Of Last Edit: 2019-09-02 08:38:48
[2019-09-02 10:44:29] |
If there is missing data in a Historical Daily or higher timeframe chart, then refer to help topic 6: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data The other post you linked to is a feature request. We are not accepting any new features: Notice: Suggestions (Currently not accepting) Also refer to: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-02 10:45:15
