Date/Time: Sun, 12 May 2024 08:31:15 +0000
1983 Bug - Commissions not used in Trade Activity log
View Count: 540
[2019-09-01 09:12:52] |
caligola - Posts: 116 |
Hello, Commissions are not used in the Trade Activity log even activating "Use Commission" in the Trade Activity Log and setting proper round turn commission in Symbol Settings. Tested with Replay I hope it helps Date Time Of Last Edit: 2019-09-01 09:16:43
[2019-09-02 11:08:20] |
Follow through the instructions here related to this: Trade Activity Log: Use Commission Make sure to follow the step to enable the Use Custom Symbol Settings Values option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
