Date/Time: Sun, 12 May 2024 07:43:00 +0000
[User Discussion] - Adding custom features to TPO chart
View Count: 910
[2019-08-31 14:25:51] |
jseppa - Posts: 18 |
Is it possible for a user to add their own features to the existing TPO study? For example, I want to add the ability to extend POC and Value Area for Merged profiles only. Also the "until future intersection" setting for merged profiles should only stop when they intersect another merged profile and not stop at unmerged or split profiles. The value area for these extensions should be shaded a different color too, and if any part of the value area intersects with another merged profile, the whole value area and poc should stop extending. Also right justified labels on the value area high/low and poc based on the merged profile start date should be configurable. I would love the ability to customize the tpo study with other further enhancements too |
[2019-09-02 13:09:41] |
No, this is not supported.
[2019-09-02 14:16:51] |
Ok, so I have 2 more questions: 1) Can the ability to extend base studies by the way of user implemented interfaces be added as a feature? 2) In theory, is it possible for a developer to re-implement the base TPO study using custom chart bars as documented here ACSIL Interface - Custom Chart Bars Cheers |
[2019-09-02 14:54:18] |
Ackin - Posts: 1865 |
jseppa) check this link...Very good work (by WarriorTrader).You can put a suggestion there to improve: Custom Market Profile Chart |
[2019-09-02 17:05:37] |
Cheers. I was thinking about this the wrong way, i just need to write a custom study to overlay objects on top of the existing TPO chart. Thanks for the tip
