Date/Time: Thu, 02 May 2024 16:44:32 +0000
Extended Line - can't save default setting
View Count: 557
[2019-08-26 10:11:53] |
User383849 - Posts: 23 |
Hi! I want to set the Extend Line tool to only extend the right edge. But it kept on defaulting to extend on both sides. I'm using build 1978. Pls advice. TQ! |
[2019-08-26 10:17:30] |
You will want to use the Ray drawing tool instead.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-26 10:17:36
[2019-08-26 10:51:56] |
Perfect! Thank you!
