Date/Time: Mon, 06 May 2024 01:34:28 +0000
market stats view
View Count: 586
[2019-08-25 12:07:50] |
User326780 - Posts: 23 |
Hi does SC offer a way of viewing market stats in a way like the image shown. I have spent quite some time trying to do it with the software and looking through the support pages. I would rather have it as a quick view than a whole chartbook. Thanks in advance. |
market stats.PNG / V - Attached On 2019-08-25 12:07:02 UTC - Size: 57.16 KB - 275 views |
[2019-08-26 10:11:44] |
For this you need to use the Quote Board feature and add those symbols you want to the Quote Board. Refer to: Getting Quotes: Quote Board Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-26 10:20:48] |
Thanks for the quick response I will being the quote board up. Cheers |
