Date/Time: Sun, 05 May 2024 02:15:01 +0000
can I display chartbook tabs on the right side of my screen?
View Count: 816
[2019-08-24 05:05:04] |
User266069 - Posts: 30 |
can I display chartbook tabs on the right side of my screen under control bar?
[2019-08-27 07:33:53] |
No, this is not supported. The only options are Top and Bottom. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#WindowAndChartbookTabs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
