Date/Time: Thu, 02 May 2024 18:50:01 +0000
fibo retracement ajastment
View Count: 554
[2019-08-23 16:35:26] |
digital.buyer - Posts: 4 |
Dear Tech Support is it possible somehow in menu "Options/Show ticks, points..." add possibility to adjust which info I can show on which level? On some level I need "%" only, on others "% & points" but if 2 parameters reflected on all levels simultaneously, retracement looks overloaded (it is not critical, but if this possible - it relief my trade) thanks! |
[2019-08-23 17:44:45] |
No, this is not supported or planned.
