Date/Time: Fri, 03 May 2024 13:12:30 +0000
Cross Instrument Trading Pairs for ES and MES??
View Count: 2180
[2019-08-23 12:55:58] |
JohnnyT - Posts: 22 |
Hi. Is it possible to trade of the ES chart, but have the orders sent to the MES? In other words, if I click on the bid at 2910, the order is sent to the MES instrument.
[2019-08-23 13:11:49] |
User316362 - Posts: 210 |
Yes. You can use the "Trade and Current Quote Symbol" in Chart settings. Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) |
[2019-08-23 13:58:04] |
Great! Thanks for the response!
[2020-08-09 04:43:59] |
User353062 - Posts: 26 |
I did set to trade MES using ES chart. Why in the trade window show currency value of ES not MES?
[2020-08-10 20:28:18] |
You need to adjust your Currency Value per Tick to be that of the MES. Refer to the information here: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
