Date/Time: Thu, 02 May 2024 06:54:44 +0000
Session Times in Chart Settings, time Zones
View Count: 2604
[2019-08-23 08:19:23] |
User656894 - Posts: 4 |
Hi Firstly are the Session time settings in chart settings referencing my current time zone ie UK time or the market im trading time Zones? Im using TPO charts for Emini S&P500 futures and Crude Light Futures and want to set the session times but am confused whether I have to allow for the time difference. What are the session times for CL and Emini and do I have to allow for time difference in time settings. Many Thanks Dean |
[2019-08-23 09:30:07] |
This depends upon the time zone. Refer to: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-23 13:11:28] |
Sawtooth - Posts: 3989 |
The Session times reference the time zone you've set. The global time zone is set here: Time Zone Setting: General Information You can override the global setting for individual charts: Time Zone Setting: Using Different Time Zone in Individual Charts What are the session times for CL and Emini?
https://www.cmegroup.com/trading-hours.htmlTimes listed here are US Central (Chicago) do I have to allow for time difference in time settings?
It's easiest if you set the Sierra time zone to Chicago time, and use Session times for Chicago.This avoids confusion at US Daylight Savings Time changes, which differ from UK. If you use another time zone setting, you'll have to allow for the time difference. |
[2019-08-27 11:18:52] |
Thanks Guys, much appriciated
