Date/Time: Wed, 08 May 2024 21:31:45 +0000
STUDY SUBGRAPH ABOVE/BELOW BAR AS TEXT
View Count: 1021
[2019-08-23 05:10:44] |
User918738 - Posts: 31 |
Hi, is there a way to display 2 study subgraph above/below as texts indicators at the same time when the conditions are met. only the results from the subgraph study with priority(due to placement in studies to graph list) is displayed. i tried using the offset but it does nothing. Thanks in advance. |
[2019-08-23 18:17:49] |
The Offset in Ticks Input is what you would want to use with Study Subgraph Above/Below Bar as Text and it definitely does work. Try using a larger value for it. But in the next release we are adding this Input: Offset in Text Heights (+/-) which will give you control of the offset based on text heights. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-23 18:18:41
[2020-05-08 16:36:52] |
hi, I cannot get the offset in text height(+/-) to work with my charts. I am pulling a value from the spreadsheet study and using the study subgraph above/below bar as text study. attached are pics that show i am trying to offset the number "9" above the bar. i tried different tick offsets but none work. in the pic, i used offset of 100 and the "9" does not move. What am i possibly doing wrong. you mentioned before that the offset is working. update: I was just playing around with the offset in ticks(ln:3) and that was moving it away from the bars. What is the difference between offset in text heights (+/-)(ln:6) and offset in ticks (in: 3)? Thanks in advance. Date Time Of Last Edit: 2020-05-08 16:57:41
Text_1.PNG / V - Attached On 2020-05-08 16:34:31 UTC - Size: 45.09 KB - 286 views text_2.PNG / V - Attached On 2020-05-08 16:34:37 UTC - Size: 57.34 KB - 271 views text 4.PNG / V - Attached On 2020-05-08 16:57:37 UTC - Size: 16.27 KB - 253 views |
[2020-05-09 01:06:50] |
We will resolve the problem with that Study Input not working with the particular Draw Style being used (it works with the Transparent one), in the next release. And we have also added documentation for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-09 01:07:38
