Date/Time: Wed, 08 May 2024 08:44:52 +0000
Number Bars Bid/Ask Min Vol Compare Threshold
View Count: 1451
[2019-08-23 03:23:00] |
dan h - Posts: 7 |
On Number Bars, the Bid/Ask Minimum Volume Compare Threshold (ln:95) only checks the extremes of bars and nothing else when Background Coloring (ln:18) is Based on Dominant Side AskVol BidVol Percentage. Cheers.
[2019-08-23 19:15:32] |
John - SC Support - Posts: 31441 |
The way we interpret what you are stating is that the Bid/Ask Minimum Volume Compare Threshold only affects the very top and/or the very bottom price levels of a numbers bar when you are using a coloring of Based on Dominant Side AskVol BidVol Percentage. But this is definitely not the case. We double checked and took a look at the code, and everything is working properly. For us, when the Bid/Ask Minimum Volume Compare Threshold is set to a value greater than both the Bid and Ask volumes, then that bar is colored the Default Background Color (In: 117). The only thing we can think of that you might be seeing is that it does require both the Bid and the Ask to be below the threshold level for it to not perform the coloring at the price level. If only one of the Bid/Ask is below the Minimum Level, then the background coloring is going to be set based on the Dominant Side Percentage. You will find the information on the Bid/Ask Minimum Volume Compare Threshold here: Numbers Bars: Bid/Ask Minimum Volume Compare Threshold For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-23 19:42:54] |
dan h - Posts: 7 |
Perhaps I am misinterpreting how it is meant to work. Please refer images below. When the threshold is set to 117 shouldn't the comparison not take place on the 48x116 imbalance?
zero_threshold_setting.PNG / V - Attached On 2019-08-23 19:37:24 UTC - Size: 48.18 KB - 468 views 117_threshold_setting.PNG / V - Attached On 2019-08-23 19:37:29 UTC - Size: 61.15 KB - 408 views Attachment Deleted. |
[2019-08-23 19:49:15] |
dan h - Posts: 7 |
I believe it is a similar issue to these: Number Bars bid ask min volume Number bar problem- Bid/Ask Minimum Volume Compare Threshold not working on ASK column |
[2019-08-23 21:40:43] |
What do you have the Background Type set to?
[2019-08-23 21:43:44] |
dan h - Posts: 7 |
Ask/Bid Volume Split Profile.
Date Time Of Last Edit: 2019-08-26 14:21:20
[2019-08-26 14:58:11] |
We have fixed this up, along with a few other places where the Ask/Bid Minimum Threshold was not being used properly for Split profile types. This will be in the next Pre-Release - v 1982. When available, you can upgrade using the instructions here: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
