Date/Time: Mon, 06 May 2024 12:57:27 +0000
[Programming Help] - more than one limit order on the same Bar Order over ACSIL
View Count: 760
[2019-08-23 02:36:47] |
User681685 - Posts: 12 |
hi.... sorry for my english first. I have a Problem to send 2 or more diffrent limit Order over ACSIL. Not the same Price! in Trading-log i become ok and diffrent ID, but the second order change the first one. and i dont know why... I cant testing it in Live with this bug. but i dont know its the problem in Replay, or Sim, or in my code... are there wrong settings? my Settings are: sc.AllowEntryWithWorkingOrders = true; sc.AllowMultipleEntriesInSameDirection = true; sc.CancelAllWorkingOrdersOnExit = false; sc.AllowOnlyOneTradePerBar = false; sc.MaximumPositionAllowed = 10; and i use folowing code for entry: uint32_t SetOrder(SCStudyInterfaceRef& sc, Struct_Entry& Entry, Struct_SL& SL, Struct_TP& TP) { s_SCNewOrder NewOrder; NewOrder.InternalOrderID = -1; SCString sModul = "SetOrder"; SCString LM = ""; //schon mal das Allgemeine NewOrder.OrderType = Entry.OrderType; NewOrder.TextTag = Entry.Info; NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED; NewOrder.Price1 = sc.RoundToTickSize(Entry.Point); NewOrder.OrderQuantity = Entry.Size; //-------------------------------------------------------------------------- //Bugfix - manchmal kommt da eine Exception in sc-suorce bei Replay wegen Empty Symbol... NewOrder.Symbol = sc.Symbol; NewOrder.TradeAccount = sc.SelectedTradeAccount; //-------------------------------------------------------------------------- /*++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++*/ //ATT-Order bestücken... if (true) { if (SL.Mode != SLTP_AUS) { if (SL.Point != 0) { NewOrder.OCOGroup1Quantity = Entry.Size; NewOrder.AttachedOrderStop1Type = SCT_ORDERTYPE_STOP; NewOrder.Stop1Price = sc.RoundToTickSize(SL.Point); } } if (TP.Mode != SLTP_AUS) { if (TP.Point != 0) { NewOrder.Target1Price = sc.RoundToTickSize(TP.Point); } } } /*++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++*/ //Order absenden t_OrderQuantity32_64 Result = 0; if (Entry.Direction > 0)//Buy Result = sc.BuyOrder(NewOrder); else Result = sc.SellOrder(NewOrder); if (GLOBAL_LoggingLevel > 0 || true) { SCString BeginDateTimeString; BeginDateTimeString = sc.FormatDateTime(sc.BaseDateTimeIn[sc.Index]); LM = "ATT-Orger gesetzt..."; LM.Format("%s: %s", sModul.GetChars(), LM.GetChars()); LM.Format("%s: Entry:[%.4f], Size:[%i] - TP1[%.4f] - SL1[%.4f] --- @:[%s]" , LM.GetChars() , NewOrder.Price1 , NewOrder.OrderQuantity , NewOrder.Target1Price , NewOrder.Stop1Price , BeginDateTimeString.GetChars() ); sc.AddMessageToLog(LM, 0); } if (Result > 0) //Order erfolgreich abgesetzt... { //Returnwerte Entry.EntryBar = sc.Index; Entry.OrderID = NewOrder.InternalOrderID; SL.OrderID = NewOrder.Stop1InternalOrderID; TP.OrderID = NewOrder.Target1InternalOrderID; SCString OR = ""; if (Entry.Direction > 0)//Buy OR = "Long"; else OR = "Short"; SCString BeginDateTimeString; BeginDateTimeString = sc.FormatDateTime(sc.BaseDateTimeIn[sc.Index]); SCString LM = ""; SCString OT = EnumOrderTypes(NewOrder.OrderType, true); LM.Format("NO1 - Order %s %s Ausgefuert Size[%i] ID:[%i] --- @:[%s]" , OR.GetChars(), OT.GetChars() , (int)NewOrder.OrderQuantity, (int)NewOrder.InternalOrderID , BeginDateTimeString.GetChars()); sc.AddMessageToLog(LM, 0); sc.AddMessageToTradeServiceLog(LM, false, true); return NewOrder.InternalOrderID; } else //etwas schief gelaufen.... { SCString LM; LM.Format("%s: - ERROR [%s]", sModul.GetChars(), sc.GetTradingErrorTextMessage(static_cast <int>(Result))); sc.AddMessageToLog(LM, 0); sc.AddMessageToTradeServiceLog(LM, false, true); return 0; } return 0; //hier sollten wir nie landen... } |
Screenshot_4.jpg / V - Attached On 2019-08-23 02:34:24 UTC - Size: 251.66 KB - 299 views Screenshot_5.jpg / V - Attached On 2019-08-23 02:35:27 UTC - Size: 174 KB - 290 views |
[2019-08-30 12:49:22] |
hallo Support....Please answer. is that what you wanted and therefore my problem? or is that a bug? My Version is 1980, but in other version is the same Problem. And I can not find any mistakes on my code.I have already tried a lot and can not continue. I make a new order one or two Ticks below/above, i dont want to modyfy the first one.
